23088 Discussions
Intel® BETA Graphics Driver for *Gears of War 4 for Windows® 10 Anniversary Update
RonaldM_Intel
*Gears of War 4 Press Release Beta Driver
This beta version driver is being made available for the Press Release and contains driver code changes that resolve crashes or unresponsiveness when playing the game *Gears of War 4 on Intel graphics devices.
A production version driver will follow in a few weeks, if the beta tests well.
Please keep in mind that Microsoft* already announced that Gears of War 4 can only run on Windows 10* Anniversary Edition.
BETA Notice
This driver is being provided as a beta test driver, and while it has had limited validation testing by Intel, it is essentially a test driver and is not to be considered a permanent replacement for a fully validated and certified graphics driver.
  • Use at your own discretion
While Intel may or may not address issues found in this beta version driver, we do welcome feedback particular to the issues listed in the ReleaseNotes that the driver addresses.
  • Please note: this driver is not certified by Microsoft* and will generate a warning when installing.
  • If you receive any installation errors (not including signature warning), delete the current driver completely and without rebooting install this driver to see if this resolves it.
The Windows BETA driver https://downloadcenter.intel.com/download/26305/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88968 15.40.xx.64.4530 has been posted to Intel Download Center at the following direct links to the driver:
These drivers below in self installing format (exe) are intended for end users.
https://downloadmirror.intel.com/26305/eng/15.40.4530%20(Beta).exe https://downloadmirror.intel.com/26305/eng/15.40.4530%20(Beta).exe
These drivers below in zip format are intended for developers and IT professionals.
https://downloadmirror.intel.com/26305/eng/15.40.4530%20(Beta).zip https://downloadmirror.intel.com/26305/eng/15.40.4530%20(Beta).zip
<table border="1" class="jiveBorder tablesorter tablesorter-default" height="200" jive-data-cell="{"color":"# 000000","textAlign":"left","padding":"2"}" jive-data-header="{"color":"# FFFFFF","backgroundColor":"# 6690BC","textAlign":"center","padding":"2","fontFamily":"intel-clear,arial,helvetica,hel...
