22905 Discussions
Intel DCH driver Silent Install Non-Interactive
Mikeh361
I'm trying to update the HD Graphics 530 drivers on systems in our environment to appease an Adobe popup about the drivers being out of date. I can update the drivers silently while I'm logged onto a system using the --fresh --silent arguments....
But, we use Configuration Manager to manage systems and so installs are run under the SYSTEM context... Looking at the IntelGFX.log file it detects that:
[INFO}Non-Interactive mode flag: True
|WARN|Non-Interactive mode flag: True. Forcing interactive mode. ||
|ERROR|Forcing interactive mode failed. ||
|INFO|Closing the user interface window. ||
|INFO|Exiting application with exit code 1... ||
There's no way I'm logging into 200+ systems to run these updates manually. Am I missing an argument that allows the drivers to be installed silently without an interactive user connected?
Alberto_R_Intel
Hello Mikeh361, I just received an update on this matter.
I just confirmed, as you mentioned, that the solution or fix that will be supplied for this scenario, based on the article, will be provided for 10th-generation processors or higher, which will be available in future graphics driver releases.
Albert R.
