22862 Discussions
Intel DSA and Windows Update driver update conflict
TimB
For UHD 750  graphics running on i5-11600K CPU in a desktop PC (not OEM), Intel DSA says 30.0.100.9684 is the latest version of the driver but Windows Update thinks 27.20.100.9466 is the latest version so they keep overwriting each other daily. What do I need to do to get version 30.0.100.9684 of the driver installed so that Windows Update doesn't roll it back to 27.20.100.9466?
DeividA_Intel
Hello TimB,
1. Have you tried reinstalling the Intel® Driver & Support Assistant (Intel® DSA)?
- Uninstaller: https://www.intel.com/content/www/us/en/download/19333/intel-driver-support-assistant-uninstaller.html?v=t
- Tool: https://www.intel.com/content/www/us/en/support/detect.html
2. Have you tried manually updating the driver?
https://www.intel.com/content/www/us/en/download/19344/30579/intel-graphics-windows-dch-drivers.html
3. Are you using a supported browser (Firefox, Chrome, Edge)?
Deivid A.
LeonWaksman
Try this:
1. In the search box write: Advanced System Settings. Click on View Advanced System Setting to open it.
2. In Hardware tab, click on Device Installation Settings.
3. Check No and then Save Changes.
Leon
TimB
Thanks for the suggestion but the driver still gets rolled back by Windows Update even after selecting 'No' in Device Installation Settings.
DeividA_Intel
Hello TimB,
Deivid A.
TimB
Hi Deivid,
I am using Chrome browser. I have tried uninstalling and re-installing the Intel Driver & Support Assistant but that didn't help. I tried manually installing the driver from the command line and that seems to have fixed the issue. The two update processes are no longer overwriting each other. Hopefully the fix will persist and the conflict won't return the next time a driver update is released.
Thanks!
DeividA_Intel
Hello TimB,
Thanks for the information provided,
I am glad to hear that you were able to fix the issue by manually installing the drivers, this information may help anyone that faces the same issue as you.
I will proceed to close this thread, however, if you present any future issues do not hesitate to let us know.
Deivid A.
