23843 Discussions
Intel Display adapter colours problem
ROBIBJN
As you can see below in some app I have that problem with black colour that flicker. If I go in device manager in disable Intel UHD Graphics solves the problem but I need that driver enable because when I  turn it off videos in youtube moves a lot slower. Clearly it is an driver problem from Intel so I want to ask you for any guide to help  me. All drivers are updated and I used Intel driver updater too.Untitled.png
JeanetteC_Intel
Hello ROBIBJN,
Here are the recommendations we have based on the SSU logs you shared:
  1. Check if the "black" washed out areas on the game is also seen outside the application.
  2. Execute a Clean Installation During Driver Installation using the latest graphics driver from our Download Center (version 31.0.101.5522).
  3. Disable HDR mode.
  4. Try to connect an external display/monitor and check if the issue persists.
We hope to get your reply soon.
Jeanette C.
JeanetteC_Intel
Hello ROBIBJN,
To better understand and assist you further, please let us know if your system a desktop PC or a laptop device. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility located at this link. After running it, you will be given an option to save the logs to a .txt file, please do so and attach the file on your reply. Can you share the display configuration such as the port you are using and the monitor model. This will help us to further identify the root cause.
I will wait for your reply.
Jeanette C.
ROBIBJN
My system is an laptop msi cyborg 15a13vf
JeanetteC_Intel
Hello ROBIBJN,
Jeanette C.
ROBIBJN
JeanetteC_Intel
Hi ROBIBJN,
Thank you for sharing this update. We're glad to know that the resolution we shared helped fix the issue.
If you would like to give us an update or if you have further questions, please submit a new question as this thread will no longer be monitored.
Thank you for contacting Intel®.
Sincerely,
Jeanette C.
