- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Intel Display/Extension 32.0.101.5768 gives installation error code 0x80070103 even though update history (Windows 11) shows successful installation.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi I just used the steps that Leon suggested. wushowhide.diagcab and now the Retry message does not appear any more.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Unfortunately the problem still exists after installing the latest driver you suggested. Every day now for weeks Windows Update says the driver I indicated in my original post failed to install with 0x80070103 error code. And yet, the Update History says the driver was successfully installed each and every day. Very strange!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
1. Try to run Windows Update Troubleshooter:
Go to Settings > System > Troubleshoot > Other troubleshooters.
Click the Run button next to Windows Update to start the troubleshooter.
2. If the Troubleshooter will not solve the problem, hide this update using Microsoft wushowhide.diagcab Tool.
Leon
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Leon,
Sadly, to no avail, running the Troubleshooter was one of the first things I tried several weeks ago. I have also tried system file checker, clearing the Windows Update cache and other online suggestions as follow-up to running the Troubleshooter. I have not yet tried a clean Windows 11 reinstall since that would entail a lot of customization/application reinstall work.
Nevertheless, I do appreciate your efforts to help resolve this problem.
Larry Heitz
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Finally!!! Running the wushowhide.diagcab Troubleshooter and then rebooting my system finally got rid of the false install error for the two Intel drivers.
Many thanks,
LarryH
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
No matter how hard I try anything regarding the Windows update status shown below the failure of the extension remains, even if the driver is updated successfully in multiple manners to Intel® Graphics Driver 32.0.101.101.6253.
I have also tried the Intel driver gfx_win_101.6793.exe as well as the Windows utility wushowhide.diagcab to successfully hide it.
I have also updated the NVidia Studio Driver to 576.52 as well and Intel Driver & Support Assistant is good.
Reboots done multiple times.
Computer is a Dell XPS 17 9710 running a Microsoft 11 Pro inline update to 24H2 from Microsoft (Dell wasn't going to update to that but their support ran with the Microsft update) and Dell's utility shows all drivers were up to date.
It still shows the same after all of this....
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Using the Windows utility wushowhide.diagcab you should hide the 32.0.101.5768 update rather then, the 32.0.101.101.6253.
Run the Windows Update troubleshooter as well.
Leon
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I did just that at the beginning, as this was a problem early in the year. It re-appeared and I just opened my notes.
It remains the only one listed when running wushowhide.diagcab. Nothing is listed any longer - yet it persists.
Dell is clueless to fix this. It appeared right after they performed an inline 24H2 upgrade - as they seemed to not ever be ready to allow the Dell to move to 24H2 out of 4 other mfr. laptops here had updated months before.
The results attached show the current state regardless of Windows Update, restarts or attempts.
Nothing listed when running wushowhide.diagcab.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Did you run the Windows Update troubleshooter as well?
You may try to repair your installation with an in place upgrade . (I suggest use the Option One). All this process will take about a hour and half. Your Windows will be replaced without affecting your application, data and settings.
Leon
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
