23696 Discussions
Intel Driver Updating Loop
Mark555
I recently downloaded the Intel Driver & Support Assistant and started updating my PC drivers. All went smoothly until I started updating the graphics drivers.
I noticed that I had to update a driver called 'Intel Graphics Driver for Windows [15.33]' a couple of times.
I updated it about 5 times just to be sure, and it was still the same.
Today I tried the Avast Driver Updater, and another loop happened, this time with a different one.
I even checked the version code and it was the same.
Is there any way to fix this?
My PC: HP 250 G3
n_scott_pearson
How recently? A fix for this looping issue was released late last week. If a reinstall of IDSA does not fix this issue, let us know.
If is does continue to loop, please create a ZIP file containing all of the files in folder C:\ProgramData\Intel\DSA\Logs and attach this ZIP file to your response post (drag ZIP file from File Explorer to the box titled Drag and drop here or browse files to attach).
After that, go into IDSA and hide this update. Rest assured it is not an issue of the driver not installing the first time.
