23807 Discussions
Intel® Driver & Support Assistant: something went wrong while trying to scan
bat1
Problem:  Unable to update drivers
SW Version: 21.2.13.9
Steps taken:
- Uninstalled with DSAUninstaller
- Deleted Cache
- Verified if the application was being blocked by AV or firewall system
- Re-installed version 21.2.13.9 & rebooted
- Different network connections tested
DeividA_Intel
Hello bat1,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Was Intel® Driver & Support Assistant working before? If so, did the issue start after a system update or change?
3. Which browser are you using?
4. Have you run all the Windows updates, including optional?
5. Share logs from Intel® Driver & Support Assistant.
- IDSA files zipped from C:\ProgramData\Intel\DSA\Logs (not just .log files.... all the files in the folder)
- IDSA files zipped from C:\ProgramData\Intel\DSA\Data (NOTE: the ProgramData folder may be hidden, File Explorer > View > Show/Hide: check the box for Hidden Items)
- Steps: copy files>desktop>paste>send to> ZIP.
Deivid A.
bat1
Hi Deivid, I was using Brave as my browser, changed it to Edge and it worked perfectly fine. Thanks for your help, have a good one
DeividA_Intel
Hello bat1,
Thank you so much for letting me know about how you resolved the issue, I am glad to know that the Intel® Driver & Support Assistant is now working properly in your system.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
