23831 Discussions
Intel Driver & Support Assistant
Borax
Ever since Windows changed the Start Menu, the Intel Driver & Support Assistant icon is now generic. I tried installing/uninstalling and tried changing the shortcut icon which works until the next start-up. This is the only program I have an issue with.
HeroS_Intel
Hi Borax
  • May I know how did you uninstall and install it?
  • Are you experiencing any issues with Intel Driver Support Assistant because of this?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Hero Yuki S.
Borax
I used the System uninstall. There is no problems with the program. I get regular updates for my graphics driver through the program.
HeroS_Intel
Hi Borax
Thank you for your prompt response. I have sent an email regarding your issue to further investigate your concern. Please check your inbox for the detailed information and next steps.
Hero Yuki S.
