23652 토론
Intel-Gfx-Display-External error
Ogmios
초급자
28,206 조회수
Setup:
  • CPU: Core Ultra 9 275HX
  • DGPU: NVidia GeForce RTX 5070 Ti Laptop
  • Hybrid GPU Mode: ON
  • External display connected to display port (DGPU based on hwinfo64 sensors data - at least while the display is active).
  • Intel Display Driver: 32.0.101.8136
  • No gaming, just simple office usage.
I have thousands of errors like this in Event Viewer every single day:
Log Name:      Intel-Gfx-Display-External/GfxDisplayExEventViewer
Source:        Intel-Gfx-Display-External
Event ID:      10
Task Category: (5)
Level:         Error
Keywords:      (128)
User:          SYSTEM
Description:   The description for Event ID 10 from source Intel-Gfx-Display-External cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
0 포인트
43 응답
DeancR_Intel
중재자
19,616 조회수
Hi Ogmios,
Thank you for reaching out about the Intel-Gfx-Display-External Event ID 10 errors you're experiencing with your Core Ultra 9 275HX system. I can see you're getting thousands of these errors daily in Event Viewer while using an external display connected to your RTX 5070 Ti via DisplayPort.
I notice you're already running the latest Intel graphics driver version 32.0.101.8136, which is good.
When did this issue start? Was this happening from the beginning, or did it start after a recent change (driver update, Windows update, etc.)?
Since this appears to be a laptop system with hybrid GPU configuration, I'd recommend using the OEM-provided graphics drivers as they're specifically optimized for your laptop's hardware configuration. However, I'll do my best to assist you with this issue.
Could you please provide an Intel SSU report for detailed system analysis? Download: https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
If you're not comfortable sharing the SSU report, please provide your exact laptop model.
If the issue persists after our troubleshooting, you may need to contact your laptop manufacturer (OEM) as they have specialized expertise with your specific hardware configuration and hybrid GPU setup.
Dean R.
0 포인트
Ondra
초급자
19,589 조회수
Same situation with me.
  • DGPU: NVidia GeForce RTX 5060 Laptop
  • NO External display
  • Intel Display Driver: 32.0.101.6629, also tested 32.0.101.8136 both with this error
When booting Windows, there is a 10 second delay between the Windows logo and the login screen, which is caused by the Intel driver, because with NVidia graphics everything starts immediately.
0 포인트
Ondra
초급자
19,588 조회수
Report here
0 포인트
Ogmios
초급자
19,530 조회수
The issue is present probably from the very beginning. I've observed it while using the vendor provided driver, and decided to update it to see if the problem would have been solved by Intel in the meanwhile. But it was not.
The error with the original, vendor provided driver:
Date:          25/10/08 19:17:57
Event ID:      10
Task Category: (5)
Level:         Error
Keywords:      (128)
User:          SYSTEM
The following information was included with the event:
<EventData>
  <Data Name="BDF">0</Data>
  <Data Name="BDF">2</Data>
  <Data Name="Source">0</Data>
  <Data Name="Param1">268435459</Data>
  <Data Name="Param2">815616</Data>
  <Data Name="Param3">134217728</Data>
  <Data Name="Param4">5500</Data>
  <Data Name="Param5">134217729</Data>
  <Data Name="Param6">0</Data>
  <Data Name="Version">32.0.101.6733</Data>
</EventData>
The message ID for the desired message could not be found​
This is the original driver from the vendor:
Custom driver version: 101.6733_0417
Build Date: April 02, 2025
(It must be based on Intel driver version 32.0.101.6733 -- but I couldn't find it anywhere to compare it with the vendor provided version.)
According to this post the issue appeared after Intel driver version 32.0.101.6042, and it affects other vendors as well.
This suggests that it's a base driver problem and not a vendor specific one.
What kind of optimizations would a vendor provide also keeping in mind the frequency of the driver releases by Intel?
I've attached the IPDT / Intel SSU report.
0 포인트
DeancR_Intel
중재자
19,517 조회수
Hi Ogmios,
Thank you for the detailed information and for providing the Intel SSU report. I can see that this Intel-Gfx-Display-External Event ID 10 error has been present from the beginning with both vendor-provided and Intel drivers, and you've provided valuable context about the issue potentially affecting multiple vendors since driver version 32.0.101.6042.
To help me analyze this issue further, could you please provide the complete Event Viewer logs following the specific instructions in this guide: https://community.intel.com/t5/Intel-ARC-Graphics/Need-help-Reporting-a-bug-or-issue-with-Arc-GPU-PLEASE-READ-THIS/m-p/1494429#M5057
This will give me more detailed information about the frequency and patterns of these Event ID 10 errors.
Hi @Ondra, I acknowledge that you're experiencing a similar issue with your Core Ultra 9 275HX system. To avoid confusion and ensure you receive focused support, could you please create a new support thread for your specific inquiry?
Dean R.
0 포인트
Ogmios
초급자
19,488 조회수
There was nothing about Event Viewer on the link.
I've exported Intel-Gfx-Display-External/GfxDisplayExEventViewer. (The logs were cleared 4 days ago).
0 포인트
DeancR_Intel
중재자
19,302 조회수
Hi Ogmios,
Thank you for providing the Event Viewer logs in the GfxDisplayExEventViewer-251017.zip file. I appreciate you exporting the Intel-Gfx-Display-External/GfxDisplayExEventViewer logs.
Before I proceed with checking this internally, I notice that you provided an IPDT report (ipdt-ultra9-275hx-251016.txt), but I need a complete Intel SSU report for proper system analysis.
Could you please provide a full Intel SSU report using the Intel System Support Utility? You can download it here: https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
The SSU report will provide more comprehensive system information that's needed for analyzing these Intel-Gfx-Display-External Event ID 10 errors on your Core Ultra 9 275HX system.
Once I receive the complete SSU report along with the Event Viewer logs you've already provided, I'll be able to check this internally for further analysis.
Dean R.
0 포인트
Ogmios
초급자
19,294 조회수
The provided link is invalid in this case... and should be:
https://intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
The following might be related to this issue, but I'm not sure yet:
When playing a video (I'm using https://mpv.io), and I'm turning off the display programmatically (using SendMessage, e.g. in AHK: SendMessage(0xF170, 0x112, 2, , "Program Manager")), the DGPU power usage goes up (e.g. from 16W to 21W in case of a 4k video and from 16W to 26W in case of streaming), even if the player window is minimized. And I can see a lot of external display errors in Event Viewer.
Once the display is back, the power consumption returns to normal.
All of this was working fine on my old laptop (also Intel IGPU + NVidia DGPU).
0 포인트
DeancR_Intel
중재자
18,964 조회수
Hi Ogmios,
Thank you for providing the detailed Event Viewer logs and the additional information about the video playback power consumption issue when turning off the display programmatically. This additional context is very helpful for understanding the scope of the problem.
I also appreciate you correcting the SSU link - you're absolutely right, and I apologize for the confusion.
Before I proceed with internal analysis of your inquiry, I need to confirm one important detail about your driver installation:
Did you perform a clean installation of the latest Intel graphics driver (32.0.101.8136)?
A clean installation involves:
  1. Using Display Driver Uninstaller (DDU) to completely remove all previous graphics drivers
  2. Restarting the system
  3. Installing the fresh Intel graphics driver
If you haven't performed a clean installation, I'd recommend doing so as it can resolve many driver-related issues, including Event Viewer errors. Sometimes remnants from previous driver installations can cause conflicts that manifest as these types of errors.
Dean R.
0 포인트
Ogmios
초급자
18,879 조회수
The driver from the vendor was installed on a brand new windows installation.
Nonetheless I did a clean install (DDU, restart, install 32.0.101.8136), cleared the Event Viewer logs just before restarting after the driver install, and already got 382 "Intel-Gfx-Display-External cannot be found" errors.
0 포인트
Ogmios
초급자
18,875 조회수
Also it is absolutely clear now that this very issue is causing the sudden temporary spikes in CPU/GPU usage I have mentioned above.
After restarting my system again and without starting any application my system was idle for long enough so that windows turned off my display. Right after that the CPU/GPU fans were turned up for a few seconds (indicating the higher temperature, power consumption and usage), and after checking Event Viewer, I could see new "Intel-Gfx-Display-External cannot be found" errors exactly from the period, when the display was turned off.
0 포인트
DeancR_Intel
중재자
18,759 조회수
Hi Ogmios,
Thank you for performing the clean driver installation and providing the detailed follow-up information. I can see that even after a clean DDU installation of driver version 32.0.101.8136, you're still experiencing the Intel-Gfx-Display-External errors (382 errors already), and you've made an excellent observation connecting these errors to the CPU/GPU usage spikes when the display turns off.
Your correlation between the display power management events and the sudden fan activity is very insightful and helps confirm that these Event Viewer errors are indeed causing real system performance impacts, not just benign log entries.
I understand how frustrating this must be, especially when you've followed all the proper troubleshooting steps including a clean installation on a fresh Windows setup. The fact that this occurs even during idle display power-off events suggests a deeper driver compatibility issue with your system's power management.
I'd like you to try updating to the latest Intel graphics driver version 32.0.101.8247, which may contain fixes for these display power management issues. You can download it here: https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
Please perform another clean installation using DDU, install this newer driver version, and monitor if the frequency of these errors decreases. The newer driver may have addressed the display power management conflicts you're experiencing.
Let me know the results after testing with the updated driver.
Dean R.
0 포인트
Slytha
초보자
18,047 조회수
Hi DeancR_Intel,
I also have this issue on my new Asus Rog Strix Scar 16 with Intel Ultra 275HX + RTX 5090 Laptop GPU.
My laptop is connected via HDMI 2.1 to an ASUS_XG27UCDMG: ROG Strix OLED XG27UCDMG | 27 to 31.5 Inches | Gaming Monitors|ROG - Republic of Gamers|ROG Global
I have a feeling this might be related to a global issue recently discovered by Zephkek and confirmed by Asus.
Zephkek/Asus-ROG-Aml-Deep-Dive: A deep dive into the ACPI.sys DPC latency problems on Asus ROG laptops
A more detailed post about my issue:
ROG Strix Scar 16 / RTX 5090 – nvlddmkm.sys Crashe... - Republic of Gamers Forum - 1120221
Other people with relevant issues:
Randomly losing ALL USB devices - Page 18 - Republic of Gamers Forum - 1091235
Since 17th of october I have 20k + eventlogs with Display-External error ID 10. When playing games or randomly opening Netflix or something I sometimes get black screen which after 30 to 60s result in a BSOD.
=> GPU enters impossible state: firmware insists OFF, Windows needs ON → driver thread blocks → 30s watchdog expires → BSOD
I have this issues with the recommended drivers from Asus and now testing with the newest Intel Gfx driver "32.0.101.8247" and they are still there.
I am a senior technical IT architect and tried everything in my knowlegde to fix/mitigate this issue.
With these settings the issue happens less:
Windows / NVIDIA Settings
  • HAGS (Hardware Accelerated GPU Scheduling) OFF
  • G-Sync / VRR OFF
  • DSC ON (Off only gets me 4K at 120Hz ofcourse)
  • NVIDIA GPU: Optimus + Dynamic in Bios (dGPU + Ultimate gave me alot black screens)
  • PCI Express Link State: max performance / disabled power savings
  • CPU: set to 100% performance mode in power plan
  • Turned off hardware acceleration in Edge / browsers / apps
  • Custom fan curve applied for stable temperatures (Using G-Helper instead of Armory Crate)
BIOS / Hardware Settings
  • BIOS GPU mode: Dynamic
  • Latest BIOS v327 installed (latest)
Monitor Settings
  • ASUS PowerSync OFF
  • Variable refresh rate and G-Sync disabled
  • DSC ON
Other
  • Fresh Windows 11 install (twice)
  • Temperature monitoring: "normal" (<85°C) topping/spiking to 95-101°C but its not load-related
  • Nvidia driver recommended by Asus (v576.65) via DDU
  • Critical recommended drivers from Asus
I hope you can read my posts on Asus and gather the intel from me and also Zephkek's post and try and make sense of it.
Kind regards,
Kevin
0 포인트
Ogmios
초급자
18,653 조회수
Same. I've also removed the Intel Graphic Software: I have only the driver itself installed from the whole installer package. The error is still the same.
But it's not only my issue. Others have raised the same question on other channels. Most users (with more basic computer skills) won't ever notice it.
Btw. why do I have to do a clean install especially with a third party tool? The installer should be able to remove all unused components and settings, while keeping the existing settings. If this is not the case then that's an installer bug, isn't it?
0 포인트
AlHill
수퍼 사용자
18,650 조회수
"Btw. why do I have to do a clean install especially with a third party tool? "
Why indeed!  Intel's increasing dependence on third party tools to do their job is not good.  Now, to beat them to the answer, they will try to convince you that it is a good thing.
[CoPilot is a virus]
0 포인트
Slytha
초보자
18,447 조회수
Hi DeancR_Intel,
Same issues here. 20k+ Display-External errors in eventviewer.
Tested recommended drivers and newest from Intel "32.0.101.8247".
Laptop: ASUS ROG Strix Scar 16 (2025)
GPU: NVIDIA RTX 5090 Laptop
CPU: Intel Ultra 9 275HX
External Monitor: ASUS ROG XG27UCDMG (4K 240 Hz, HDMI 2.1)
As I am an IT Architect myself, I have tried everything to mitigate or resolve the issue.
A post about my issue: ROG Strix Scar 16 / RTX 5090 – nvlddmkm.sys Crashe... - Republic of Gamers Forum - 1120221
Might be related to a global issue, detailed post & confirmed by Asus: Zephkek/Asus-ROG-Aml-Deep-Dive: A deep dive into the ACPI.sys DPC latency problems on Asus ROG laptops
Alot of other posts about these issues can be found.
Hopefully you can read the posts and try and make sense of the issue.
If you need anything i'll try to help.
Kind regards,
Kevin S.
0 포인트
Slytha
초보자
18,399 조회수
Here is the exact sequence of events that matches what i'm seeing:
  • The Hang (Time: 0 seconds): The firmware/OS conflict happens. The nvlddmkm.sys driver thread, which is responsible for the display, enters the "impossible state" and freezes.
  • The Black Screen (Time: 0.1 seconds): Because the driver thread is frozen, it stops sending a signal to the monitor. The screen immediately goes black.
  • The Countdown (Time: 0.1s to 30s): The rest of Windows is still running. A kernel-level "watchdog" timer sees that this critical system thread is no longer responding. This watchdog's job is to prevent the entire OS from being permanently frozen. It starts a countdown, which is typically 30 seconds. This is the 30-60 second delay i am actively counting.
  • The Bugcheck (Time: ~30-60 seconds): The timer expires. The watchdog says, "The thread is dead. The system is in an unrecoverable state." It then intentionally triggers the BSOD (the 0x7E bugcheck) to collect the memory dump and force a reboot.
0 포인트
DeancR_Intel
중재자
18,104 조회수
Hi Ogmios,
Thank you for testing the latest driver version 32.0.101.8247 and providing the update. I understand your frustration that the Intel-Gfx-Display-External errors persist even after the clean installation and removing the Intel Graphics Software, keeping only the driver itself.
I also acknowledge your observation that this issue affects other users across various channels, and you're correct that many users with basic computer skills may not notice these Event Viewer errors, even though they can impact system performance as you've documented with the CPU/GPU usage spikes during display power management.
Given that this issue persists across multiple driver versions and affects multiple users, I'll document your findings for further investigation. Your detailed analysis of the correlation between display power management and system performance impacts provides valuable data for. I will get back to you once I have the information you need.
Hi @Slytha, thank you for sharing your experience with similar issues on your ASUS ROG Strix Scar 16 system. To ensure you receive focused support for your specific hardware configuration and the nvlddmkm.sys crashes you're experiencing, I'd recommend creating a separate support thread. This will allow us to provide targeted assistance for your RTX 5090/Ultra 9 275HX setup and the ACPI.sys DPC latency issues you've referenced.
Dean R.
0 포인트
DeancR_Intel
중재자
17,929 조회수
Hi Ogmios,
Thank you for your patience and the comprehensive troubleshooting you've performed regarding the persistent Intel-Gfx-Display-External Event ID 10 errors on your Core Ultra 9 275HX system.
I want to update you on the status of your case. We are currently investigating this display power management issue, and I can confirm that similar instances have been identified on related platforms. Your detailed Event Viewer logs and thorough testing across multiple driver versions provide valuable data for our investigation.
I understand how disruptive these 382+ daily errors must be to your system performance, especially during video playback. I'll keep you updated on our investigation progress and any potential workarounds or solutions that become available. Thank you for providing such detailed documentation, it's invaluable for resolving this issue.
Dean R.
0 포인트
응답
