23820 Discussions
Intel Graphic Command Center using port 5000
Patrick_Hume
Not sure how to get this to Intel but their Intel Graphic Command Center software is running on port 5000 which is typically used b Microsoft .NET applications when doing development, rather than have to change all my .NET applications to use another port, could Intel release an update to there Intel Graphic Command Center software to NOt use this port please because a lot of developers are going to have a bad time otherwise 😄
Many thanks
P
Tzarot
This is totally absurd. My dev environment is broken. This should be made configurable !!!
The request to Intel support is very clear:
DO NOT CLOSE THE TICKET until you provide a method to make the whatever port is used by Intel Graphics Command Center Service under Windows CONFIGURABLE!.
