23801 Discussions
Intel Graphic Command Center using port 5000
Patrick_Hume
Not sure how to get this to Intel but their Intel Graphic Command Center software is running on port 5000 which is typically used b Microsoft .NET applications when doing development, rather than have to change all my .NET applications to use another port, could Intel release an update to there Intel Graphic Command Center software to NOt use this port please because a lot of developers are going to have a bad time otherwise 😄
Many thanks
P
Jocelyn_Intel
Hello, @Patrick_Hume
Thank you for posting on the Intel® communities.
Your comment is really important for us and has been added to our records now, we really appreciate your feedback on this matter.
Apart from this, Is there any assistance you need? Please let us know and we will gladly assist you.
Jocelyn M.
VicO
Count me as one of those .NET developers who are going to have a bad time with this 😠
I just wasted a bunch of my time trying to figure out why my port 5000 was suddenly in use. This needs to fixed ASAP!
Jocelyn_Intel
I am sorry to hear that you are having a bad time with this. I have passed the feedback to the proper team and explained the situation that you are going through as a developer for visibility.
Since you have no more inquiries, this thread will no longer be monitored, but if you need further assistance with another matter, please feel free to contact us back and submit a new post.
Have a rest of the week.
Jocelyn M.
VicO
Hello?!?! Does my response not count towards keeping this thread active?
Patrick_Hume
I have to keep killing the process just so I can do dev work, lucky only need to do it on login/reboot, took me ages to work out what the cause was though
so I tried to reserver this port using
netsh int ipv4 remove excludedportrange protocol=tcp startport=5000 numberofports=1
But that didn't work, There is an entire Stackoverflow post with users having similar problems (stackoverflow.com ), most Mac users but has some Windows workarounds. Personally, I didn't want to have to alter my  .NET  projects to run on a different port as I shouldn't have to and I have too many to alter. I just hope they release an update to fix this 🙄
VicO
I just went into Services and stopped and disabled the "Intel(R) Graphics Command Center Service" service. This has worked around the defect for me.
Rantanplan
Done that also, but now on Windows Startup the "Driver & Support Assistant" ist not autostarted anymore.
Rantanplan
With new version 31.0.101.4672 the service is switched to "automatic" again, port 5000 is still occupied (while this service is running), but the tray icon for "Driver & Support Assistant" seems to be back.
RLagrange
Hi @Jocelyn_Intel , same issue here, the driver update prevent our app to start by taking the 5000 TCP port.
User-01010101
Hi Jocelyn,
I have the same issue, intel shouldn't use port 5000.
Intel really needs to solve this problem, it creates a lot of problems for developers. I didn't have these issues with AMD.
Thank you
RafaStopUsing5000
Seriously why this ppl decide it was a good idea on using a port that is mainly using for dev work.
Been debugging my Flask app for 3 hours now...
Rantanplan
I'm afraid this is getting forgotten. Maybe closed due to inactivity by us users soon?
No sign this has been accepted as an real issue by Intel, and several driver updates not changing the behavior. Just installed 31.0.101.4887 today with the problem still going on.
What can we do to highlight this issue?
RLagrange
create new topics everyday and flood the forum ?
Patrick_Hume
I have logged a support ticket with Intel (Support Request 06014177), I don’t know how long or even if they will reply to it but will post any updates I get here. I should have done this back at the start, but I don’t recall being able to find a way to contact Intel to raise an issue with them until now, I must have somehow missed it... anyway will keep you all apprised.
Seams they have done this before with other commonly used ports https://community.intel.com/t5/Graphics/Intel-graphics-command-center-service-use-port-9001-how-can-I/m-p/719129
Will recreate a new message on the forum if I don’t get a reply soon to re-raise the issue with them
Patrick_Hume
The latest reply from Intel:
Hello Patrick,
Thanks for your patience.
This is to inform you that feedback has been passed internally to IGCC developers.
Please be informed that the respective port is not assigned permanently to the Microsoft .NET services and other services run on that port as well.
We look forward to your kind reply. In the event that you no longer need our assistance at the moment, please give us feedback to be able to close this case.
Sign in to view and update your request or to get additional information. You can also reply to this email with questions or comments.
Intel Customer Support
HI Pietro
I would argue that whilst there may be some services that use port 5000 (not that I have ever found any in the 15 years of my .net profession)  they obviously are not commonly used, or do not hold onto the port or use it for long as such applications would be well known and avoided by .net developers (of which there are many). If you read the thread, you can see many .net developers are simply blocking the intel command centre from even running, so simply claiming that it's used by other services is not exactly accurate and doesn’t resolve the issue of those who use Intel products but do not want their work hampered by such an inconvenience. There are plenty of other port numbers the application can use so surely changing to another should not be a mammoth feet for such a prestigious company as intel
P Hume
Hello Patrick,
Thanks for your feedback.
As mentioned before, your issue has been passed internally to IGCC developers who will work to solve the problem.
We inform you that we will proceed with the closure of the case.
If you have any further questions or need further assistance regarding this report, you can respond to this email within 14 days and the file will be reopened.
Kind regards.
RLagrange
How I hate when the support close the ticket saying "information is forwarded"...
Yeah, so even if they changed the tcp port, we will not be notified...
LordofLightning
Count me in with this. I have a whole team that is experiencing this issue. Disabling the service works until a new version comes and reenables the service. I do find it funny that everything appears to work with this service disabled... What is the point of it? And yes, they should look at the .net documentation to know that using port 5000 is a bad idea. Pick something to host kestrel in a much higher ranger intel.
VodniDrak
It is actually big security issue, as it listens not only on local host, but on all interfaces too. Intel setup also adds rule to the Windows firewall to allow external access to the port 5000 from whole network!
Only safe solution is to disable the `igccservice` (Service for Intel(R) Graphics Command Center) in Services.
AlHill
The real "only safe solution" is to ban intel from doing software development.   Just take a look at IDSA, XTU, Graphics drivers, BT driver trash, etc. etc. etc.
They will quietly fix this, and not make any annoucements, just like they did with the trash in the BT installs.
AndrewC1
My development environment stopped working after an Intel drive update. I found the Intel(R) Graphics Command Center) was listening on port 5000 and disabling the Intel(R) Graphics Command Center) in Services resolved the problem.
