23468 Discussions
Intel Graphics 530, Where is the register settings values
JS20
Hello Everybody,
I tried to find the Profile settings in Register Windows as shows the following link: (https://www.intel.com/content/www/us/en/support/articles/000005857/graphics.html)
But in windows 10, there aren't not path:
Computer > HKEY_CURRENT_USER > Software > Intel > Display > igfxcui > profiles
Do you know where is the correct path, in windows 10?
And where is the value to change the scalling (Maintain the Aspect Scalling) in the Windows Register?
AndrewG_Intel
Hello @JS20
In order to review these inquiries further, could you please provide us with the following details?
1- What is the purpose or use case for this request? Is this for the deployment of configuration on several machines? Is this for a work or home environment?
2- Just to make sure, have you previously saved a Profile on the computer where you're trying to find and export the registry files?
3- Regarding the inquiry about changing the scaling, is this to change it on a built-in/flat panel display (e.g.: a laptop's display), an external display, or both? Also, did you mean "Maintain Display Scaling" or "Maintain Aspect Ratio"?
4- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system:
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
AndrewG_Intel
Hello JS20
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
AndrewG_Intel
Hello JS20
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
