23840 Discussions
Intel Graphics Control Panel is not starting
MPéte1
The new UWD driver is installed successfully, but the Control Panel is not starting.
I restared my computer multiple times, but no luck. I use Windows 10 Home operating system,
an my notebook use the Intel UHD 620.
I haven't got any problems with the old drivers.
CMile1
Hahahaha, love how Intel and Microsoft can screw up something that used to be so simple.
I don't get it, what's the problem of including graphic panel in the driver ?!?! We've had it all these years !!
If Microsoft wants to add their version they can put it up on their store or include it in Windows update.
I don't have Microsoft Store, I use offline account and I have removed all Metro (cr)apps.
r3un1on
Hi Cile,
I think you got it wrong. Intel and Microsoft are doing the right thing. You do not need a Microsoft account for Windows 10 Store. Unless you want to buy something from there.
Control Panel comes automatically from Windows Update ... as soon as you install a DCH driver. ok now ... DCH drivers are mainly for industrial operating systems. Because on a windows server or workstation, control panel has to be installed separately. You can only run the control panel via icons on desktop or start menu.
If you want the control panel as usual with the driver together, you have to wait for the next driver.
Make sure that the driver name does not have a DCH entry
And as I've heard, a new intel graphic driver is coming soon. We have to be patient...
CMile1
Thanks igpu,
That make sense, however I have not found anything about this driver being released only for industrial/server version of MS OS but let's hope you are right
r3un1on
Cile@
no Problem
DCH driver is not just for industry OS. That is for all Windows OS. Only difference is that the control panel is installed via windows update. So who has Windows Server 2012/2016 need the DCH Driver.
CMile1
I hope you are right, I am eagerly awaiting the driver "for the rest of us" with graphic panel included..
dublinman1990
Hi there OP. I had found the Intel Grpahics Control Panel from the Windows Store app in Ireland. I downloaded & installed the app onto my Toshiba Satellite laptop. I discovered that the app from here is only available for integrated touch displays. There is a problem with my device with it not having a touch display at all. It said from the minimum & recommend spec that this function was needed for the app to work on my device. I don't know how Intel distribute this app myself because I don't know if the app has the exact same requirements in every other country as well as from Ireland. I could only assume here that for now I am stuck in the same position as you OP. This is because I do not own a device with a touch display. I think we may have to wait & be patient until Intel can release it for the rest of us who don't have touch displays yet. If they release it; we may get an updated app from Intel in the Windows Store or receive the new drivers through the IDSA. This will allow us to have it working on our own personal devices afterwards. For now the only answer that I can tell you is do a wait & see approach with this stuff from Intel.
LHodg
Same here. I got "Intel Graphics Control Panel" in latest Windows update. I launch it, it and it just dies immediately. No window even opens. What' s the point of it. What should it do? 🙂
