23801 Discussions
Intel Graphics Control Panel not opening!!
SMarn
After I Updated my "Intel UHD Graphics 620" graphics driver to 26.20.200.7323 version Panel says "Graphics Driver Not Available. Check the driver status and lauch the application." But if I roll back my graphics driver to previous version panel opens easily. Please HELP!!Screenshot 13-Feb-20 4_52_02 PM.png
n_scott_pearson
I would add that there are *many* builds after 7323 that may address this issue. It is unclear to me why you would go backwards instead of forward. The very latest build is 7755; you can download this build from here: https://downloadcenter.intel.com/download/29335/Intel-Graphics-Windows-10-DCH-Drivers?product=126789.
I would also add that the Intel Graphics Control Panel has been superseded by the Intel Graphics Command Center. You should not be using the Intel Graphics Control Panel any longer (though there is a Metro version of this available).
SMarn
Graphics Version Is 26.20.100.7323
Gh0stb1t
What is the version of the previous graphics that works fine (The one you are doing rollback)?
This problem is expected ifyou are trying to update the graphics from a non-DCH driver to a DCH without using a custom driver from your system manufacturer (not from Intel) or without performing a clean install. Share a SSU report to check further:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
SMarn
I have a DCH driver.And The version of rollback driver is 25.20.100.6577 But I got the help from n.scott.pearson thanks for your help also.
n_scott_pearson
SMarn
Thak you so much thank you 100 times.
Max44
If not try open Settings>System>Display on this page click on Advances Display Settings, when this page opens scroll to and click on Display Adapter Properties and this will launch box with Graphics controls and the right tab for control panel. You can also click on the Intel HD graphics icon in the control panel.
