Ankündigungen
22760 Diskussionen
Intel Graphics Driver Issue for Valorant
Saboteur
Einsteiger
2.067Aufrufe
I have installed a game 'Valorant' which used to run fine. Until recently after I had reset the laptop from the setting options.
My game crashes due to a particular DDL.
The event viewer is showing the following:
Faulting application name: VALORANT-Win64-Shipping.exe, version: 0.0.0.0, time stamp: 0x00000000
Faulting module name: igd10iumd64.dll_unloaded, version: 32.0.101.6790, time stamp: 0x680fb1cb
Exception code: 0xc0000005
Fault offset: 0x0000000000030e80
Faulting process id: 0x1F9C
Faulting application start time: 0x1DC2857E16D3AFA
Faulting application path: C:\Riot Games\VALORANT\live\ShooterGame\Binaries\Win64\VALORANT-Win64-Shipping.exe
Faulting module path: igd10iumd64.dll
Report Id: e2368b73-4f31-4184-84c0-2142449556e5
Faulting package full name:
Faulting package-relative application ID:
I have used DDU and made a clean install multiple times. The game it work yesterday for a few hours after which it started giving the same error and the game crashes will starting it.
I have checked for all the updates and it is up-to-date.
This is happening frequently.
12 Antworten
RandyT_Intel
1.923Aufrufe
Hi @Saboteur,
Thank you for posting in the community. To better assist you with your concern, please provide additional information by answering the questions below.
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Which digital distribution platform did you obtain the game that is experiencing crashing issue? (e.g., Steam, Epic Games Store, GOG, etc.)
  • Are you downloading drivers from Intel directly or using Windows Update/laptop manufacturer?
  • Does the crash happen at a specific point (startup, during gameplay, loading screens)?
  • Can you generate a detailed crash log report for Valorant by following the steps in this article: Need help? Reporting a bug or issue with Arc GPU? - PLEASE READ THIS FIRST! - Intel Community, This will give us more detailed information about what's happening when the game crashes.
  • Can you check Device Manager under "Display adapters" - do you see any error messages, warning signs (yellow triangles), or unknown devices listed there?
Randy T.
Saboteur
Einsteiger
1.891Aufrufe
    • I have attached the  SSU log report.
    • Digital distribution platform of the game is Riot Games.
    • I have tried downloading drivers from Intel directly as well as using Windows Update/laptop manufacturer. (Still the issue is the same)
    • The games crashes at startup
    • SystemLogs-2025-09-19.zip has the Valorant game log
    • There are no warning signs or unknown devices listed in the Display adapters. But in the properties of the 'Intel(R) Iris(R) Xe Graphics', Event shows 'Device not started (igfxn)'
      INFORMATION:
      Device PCI\VEN_8086&DEV_46A6&SUBSYS_1CCC1043&REV_0C\3&11583659&0&10 had a problem starting.
      Driver Name: oem18.inf
      Class GUID: {4d36e968-e325-11ce-bfc1-08002be10318}
      Service: igfxn
      Lower Filters:
      Upper Filters:
      Problem: 0x0
      Problem Status: 0xC00000E5
      (Screen shot is attached)
RandyT_Intel
1.794Aufrufe
Hi @Saboteur,
Thank you for providing the necessary information. Based on the SSU log report, I noticed that your current graphics driver version is 32.0.101.6790, which is outdated. The latest version available is 32.0.101.7029, and it appears that previous update attempts may not have been successfully applied.
To ensure a clean installation, we’ll use DDU (Display Driver Uninstaller) and follow a step-by-step process. Please temporarily disable Windows Update during this procedure to avoid interference. You can follow the instructions in Windows* Update Rolling Back Graphics Driver to a Previous Version carefully—especially the part about not selecting "Execute Clean Installation" during the driver setup.
Step-by-Step Instructions:
  1. Download DDU (Display Driver Uninstaller).
  2. Download the latest graphics driver installer: version 32.0.101.7029.
  3. Boot into Windows Safe Mode:
  4. Press Win + R
  5. type, msconfig
    1. Go to the Boot tab → check Safe boot with Networking → click Apply and OK.
  6. Run DDU:
    1. Select all GPU options.
    2. Proceed with the uninstallation.
    3. Wait for the system to restart.
  7. Note: If the system doesn’t boot normally, don’t panic. Force restart using the power button.
  8. Once back in Windows:
    1. Open Device Manager and confirm the GPU is listed as Microsoft Display Adapter.
  9. Disable Safe Mode via
  10. type, msconfig
    1. Go to the Boot tab → Uncheck Safe boot with Networking → click Apply and OK.
    2. Restart
  11. Once back in Windows:
  12. Locate and run the graphics driver installer.
    1. Follow the on-screen instructions.
    2. Do not check the box for “Execute Clean Installation.”
  13. Reboot the system.
  14. After reboot:
    1. Verify the driver update in Device Manager and Intel Graphics Software.
    2. Launch the game and test for any crashes.
If the issue persists after this process, please let me know. We’ll proceed with Plan B which involved updating BIOS to its latest version., as I suspect this may be a driver conflict caused by the recent system reset.
Thank you for your patience and cooperation. Let me know how it goes or if you need further assistance.
Randy T.
liweeeee22
Einsteiger
1.658Aufrufe
hello i had the same problem as well and i downloaded the newest version 32.0.101.7029 , but after installing it. my valorant is so much more laggier than before and my fps drops like crazy and stutters alot. please help me out. i even scanned for any updates but the intel website scanned for nothing.
Saboteur
Einsteiger
1.547Aufrufe
Thank you for the all the steps you have provided but the issue still persists. The game crashes with the same error report.
Also in Device manager, it is yet saying Device not started as mentioned before. (Screenshot attached).
Let's move to Plan B
RandyT_Intel
1.599Aufrufe
Hi @liweeeee22,
To further assist you, please consider creating a separate thread so we can follow up and investigate the issue properly. You may also try the resolution steps I provided above.
Randy T.
RandyT_Intel
1.530Aufrufe
Hi @Saboteur,
Can we try performing a clean driver uninstall using DDU again, and then install graphics driver version 32.0.101.7076 instead? Please let me know if you notice any difference afterward. No need to update the BIOS, based on my checks, your current version is already the latest.
Randy T.
RandyT_Intel
1.354Aufrufe
Hi @Saboteur,
I'm following up on the previous recommendation I provided. Have you had a chance to review the information and apply it to your system? Please let me know the outcome so I can determine the next best course of action.
Randy T.
Saboteur
Einsteiger
1.286Aufrufe
Hi @RandyT_Intel ,
After the update, the game seems to be working fine, no issues there but why the intel graphics still shows device not started in the events table of its properties (As shown earlier in the screenshot). That is the only concern now. Thanks
RandyT_Intel
910Aufrufe
Hi @Saboteur,
Thank you for the update! I'm really glad to hear that your game is working perfectly fine after the 32.0.101.7076 update that's exactly what we wanted to achieve. Regarding your concern about the Intel graphics still showing "device not started" in the events table, let me explain what's likely happening here. What you're seeing in the Events tab is actually a history of previous events that occurred on your system, not current active problems. Think of it like a logbook that keeps track of everything that happened before, including when we were troubleshooting your original issue. Since your system performance, gaming experience, and overall stability are all working normally now, these event entries are most likely just historical records from when the system was having problems or during driver installations and updates. Sometimes Windows keeps showing these old events even after the issues are resolved, and it can also be a cosmetic error where the operating system repeatedly logs driver detection activities that aren't actually causing any real problems.
Here's what I'd recommend if you want to investigate this further: first, could you please take a fresh screenshot of your Device Manager right now showing the current status of your Intel Graphics device? This will help us see if there are any actual current issues versus just old logged events. You might also want to try rebooting your system completely and then check the events again to see if any new entries appear. Sometimes waiting for the next Windows update can also resolve these kinds of logging inconsistencies automatically. However, if you're still concerned about these specific Intel Graphics event messages and want a more detailed investigation, you could consider submitting a new support thread focused specifically on this Intel Graphics logging issue, or even better, contact your laptop manufacturer directly since they would have the most detailed insights about how their specific hardware interacts with Windows and what these particular error messages mean for your exact laptop model. But honestly, since your original gaming problem has been completely resolved and your system is performing well with good stability, this seems to be just a minor logging concern rather than something that's actually affecting your computer's functionality.
Please let me know if you need any other assistance from my end!
Randy T.
RandyT_Intel
790Aufrufe
Hi @Saboteur,
Randy T.
RandyT_Intel
672Aufrufe
Hi @Saboteur,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance for the Intel Graphics device manager logging issue .
Randy T.
Antworten
