23848 Discussions
Intel Graphics Software 32.0.101.6972 errors
troutfisher
I have encountered the same issue as user LT7879:
Event viewer:
<System>
  <Provider Name="Intel.GraphicsSoftware.App" />
  <EventID Qualifiers="0">189</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>32417</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2025-07-25T07:45:49.3553467Z" />
  <EventRecordID>80300</EventRecordID>
  <Correlation />
  <Execution ProcessID="7388" ThreadID="0" />
  <Channel>Intel Graphics Software</Channel>
  <Computer>Laptop</Computer>
  <Security />
  </System>
 <EventData>
  <Data>{"category":"Igcl","level":"Error","message":"ctlEnumLeds, result=1073741834"}</Data>
  </EventData>
  </Event>
<System>
  <EventID Qualifiers="0">190</EventID>
  <Level>2</Level>
  <Task>32417</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2025-07-25T07:45:49.3557289Z" />
  <EventRecordID>80301</EventRecordID>
  <Correlation />
  <Security />
  </System>
<EventData>
  <Data>{"category":"Igcl","level":"Error","message":"3rd Party - IGCL ctlEnumLeds - Exception","parameters":{"result":1073741834}}</Data>
  </EventData>
  </Event>
Before the above error  appears, the following warning is displayed:
"The Intel(R) Graphics System Controller Firmware Interface is being reset."
I have attached the result text file of the execution ofSSU.exe.
Please advise
Thank you
troutfisher
Hi Randy,
I rebooted the pc again and now the error messages are gone! Thank you for your advice.
Best Regards
RandyT_Intel
Hi @troutfisher,
  • When did the issue first occur?
  • Have you made any software or hardware changes to the system recently?
  • What troubleshooting steps have you tried so far?
  • Have you previously performed a clean installation of the graphics driver, before using either an older or the latest version?
Randy T.
troutfisher
  • When did the issue first occur? I don't know for sure but the first occurrence is about 3 weeks ago.
  • What troubleshooting steps have you tried so far? I reinstalled the driver Intel Driver, I uninstalled and reinstalled Windows update KB5062660
  • Have you previously performed a clean installation of the graphics driver, before using either an older or the latest version? I used the clean installation option once for the reinstallation of the intel driver.
RandyT_Intel
Hi @troutfisher,
Please try the following recommendations:
  1. Perform a clean installation using DDU – Kindly follow the steps outlined in the article provided.-How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
  2. Reinstall the latest driver version 32.0.101.6972 – During the setup process, do not select the clean installation option. Please refer to the related article for guidance.-Windows* Update Rolling Back Graphics Driver to a Previous Version
Let me know how it goes or if you need further assistance.
Randy T.
troutfisher
Hi Randy,
I did as you suggested and uninstalled the Display Driver using DDU with Windows in safe mode. Then, in normal mode again I reinstalled the latest version of the driver 32.0.101.6972. But the error messages in the event viewer still show up:
<System>
  <EventID Qualifiers="0">186</EventID>
  <Level>2</Level>
  <Task>59052</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2025-08-01T05:47:53.3199162Z" />
  <EventRecordID>87278</EventRecordID>
  <Correlation />
  <Execution ProcessID="3080" ThreadID="0" />
  <Computer>Laptop-Silvin</Computer>
  <Security />
  </System>
<EventData>
  <Data>{"category":"Igcl","level":"Error","message":"ctlPciGetState, result=1073741849"}</Data>
  </EventData>
</Event>
<System>
  <EventID Qualifiers="0">187</EventID>
  <Level>2</Level>
  <Task>59052</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2025-08-01T05:47:53.3205586Z" />
  <EventRecordID>87279</EventRecordID>
  <Correlation />
  <Security />
  </System>
<EventData>
  <Data>{"category":"Igcl","level":"Error","message":"3rd Party - IGCL ctlPciGetState - Exception"}</Data>
  </EventData>
  </Event>
 <System>
  <EventID Qualifiers="0">191</EventID>
  <Level>2</Level>
  <Task>59052</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2025-08-01T05:47:53.3233605Z" />
  <EventRecordID>87283</EventRecordID>
  <Correlation />
  <Security />
  </System>
<EventData>
  <Data>{"category":"Igcl","level":"Error","message":"ctlPciGetProperties, result=1073741849"}</Data>
  </EventData>
  </Event>
<System>
  <EventID Qualifiers="0">200</EventID>
  <Level>2</Level>
  <Task>59052</Task>
  <Opcode>0</Opcode>
  <TimeCreated SystemTime="2025-08-01T05:47:53.3291932Z" />
  <EventRecordID>87292</EventRecordID>
  <Correlation />
  <Security />
  </System>
<EventData>
  </EventData>
  </Event>
troutfisher
Hi Randy,
Best Regards
RandyT_Intel
Hi @troutfisher,
Glad to hear the issue is resolved!
As this case is now closed, this thread will no longer be monitored. If you encounter any issues in the future, please feel free to submit a new support ticket.
Thank you!
Randy T.
