23094 Discussions
Intel Graphics Software freezes when changing "scaling mode" in Windows 10 22H2
frmwrk1730
In Windows 10 22H2, which is officially supported by the driver, the entire intel graphics software application just freezes when changing the Scaling Mode setting.
It changes properly on Windows 11.
After it freezes, it doesn't open again unless forcibly ended in task manager. When reopening it, the setting doesn't change to what was selected when it froze, so it's impossible to change the setting.
This is using the latest version of the driver, but I also tried many older versions and they all exhibit the same issue.
A video showing the issue is attached.
Steps to reproduce:
1. Attempt to change the scaling mode settings in intel graphics software
2. Observe how the application freezes and stops working
ssu.txt is attached
Mike_Intel
Hello frmwrk1730,
  1. When did you purchase your system?
  2. What is the brand and model of your system?
  3. Was it working fine before?
  4. Did you change any settings before the issue started?
  5. Just to check, this is working fine with Windows 11?
Michael L.
DevMo
Hello, I am also having this issue with my brand new intel arc b580, I have not been able to verify if this issue has occurred on other driver revisions or other intel graphics cards.
Any time I try to change the "scaling mode" or "scaling method"  option, first the screen goes black for about 2-3 seconds, and then the Intel Graphics Software application completely freezes, it cannot be closed from the tab or from the taskbar, as well as the pop up icon from the arrow in Windows 10, it has to be killed with Task Manager.
My PC:
Processor AMD Ryzen 7 5700X3D 8-Core Processor 3.00 GHz
Installed RAM 16.0 GB
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Asrock Intel Arc B580 Steel Legend
Windows 10 Pro Version 10.0.19045 Build 19045
Intel Driver Version: 32.0.101.6257
jackharvest
Same here. Intel Arc B580. Windows 10 22H2, latest updates.
Scaling Mode being moved to GPU Scaling = 1-2 second blip of black, then its stuck like this:
Interestingly, I get the same results when changing the bit-range from 10 to 8 (but that one actually successfully changes to 8, despite the intel graphics software app completely freezing up).
My PC:
Processor AMD Ryzen 7 8845HS w/ Radeon 780M Graphics 3.80 GHz
Installed RAM 48.0 GB (46.8 GB usable)
Asrock Intel Arc B580 Challenger
Mike_Intel
Hello frmwrk1730,
@jackharvest and @DevMo
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Mike_Intel
Hello frmwrk1730,
I am sending another follow up on the information that I requested.
Michael L.
