22680 Discussions
Intel Graphics Software says my current configuration isn't supported by Intel Graphics Software
Cidney
I tried playing a game, but it was very slow. So, I went into Intel Graphics Software and it told me that my current system configuration wasn't supported.
My drivers are up to date and enabled within Device Manager. However, I did do a clean install of the newest update, meaning I deleted a lot of stuff previously for the new update (maybe that has something to do with it.)
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"01/22/2025"
Time:"00:00:26.1324304"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"HP"
BIOS Mode:"UEFI"
BIOS Version/Date:"Insyde F.35 , 07/06/2022 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"48.46"
Platform Role:"Mobile"
Processor:"11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.3"
Sound Card:"Realtek High Definition Audio"
Sound Card:"Intel® Smart Sound Technology for Bluetooth® Audio"
Sound Card:"Intel® Smart Sound Technology for Digital Microphones"
Sound Card:"Intel® Smart Sound Technology for USB Audio"
System Manufacturer:"HP"
System Model:"HP ENVY x360 Convertible 15-ed1xxx"
System SKU:"389F2UA#ABA"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Iris(R) Xe Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(R) Xe Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Xe+Graphics"
CoInstallers:"oem56.inf,iTGLD_w10_DS,Internal,Intel(R) Iris(R) Xe Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdn64.sys"
Driver Date:"12/02/2021 07:00 PM"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_e7a66f741a7f70e8\igdkmdn64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"30.0.101.1191"
INF:"oem56.inf"
INF Section:"iTGLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e7a66f741a7f70e8\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e7a66f741a7f70e8\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e7a66f741a7f70e8\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e7a66f741a7f70e8\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_9A49&SUBSYS_8825103C&REV_01\3&11583659&2&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"40 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfxn"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(R) Xe Graphics Family"
- "Memory"
Physical Memory (Available):"0.74 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7.77 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"Bottom - Slot 1 (left)"
Configured Clock Speed:"3200 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First position"
Manufacturer:"Kingston"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"HP32D4S2S1ME-4"
Serial Number:"0BCAA023"
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"4 GB"
Channel:"Bottom - Slot 2 (right)"
Serial Number:"F28AA053"
Type:"Synchronous"
- "Motherboard"
BIOS:"F.35, HPQOEM - 2"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"07/05/2022 08:00 PM"
Manufacturer:"HP"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"8825"
Serial Number:"PKUMCH21WF9BN4"
Status:"OK"
Version:"48.46"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Intel(R) Wi-Fi 6 AX201 160MHz"
Access Point:
Authentication:"WPA2-Personal"
- "Caption":"Intel(R) Wi-Fi 6 AX201 160MHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6+AX201+160MHz"
Channel:"36"
Cipher:"CCMP"
CoInstallers:"Not Available"
Connection Mode:"Auto Connect"
Default IP Gateway:"192.168.12.1;fe80::c6e5:32ff:fedc:d9f0"
DHCP Enabled:"Yes"
DHCP Lease Expires:"01/29/2025 01:33 AM"
DHCP Lease Obtained:"01/22/2025 01:33 AM"
DHCP Server:"192.168.12.1"
Driver:"Netwtw10.sys"
Driver Date:"11/11/2024 12:00 AM"
Driver Path:"C:\WINDOWS\system32\drivers\Netwtw10.sys"
Driver Provider:"Intel"
Driver Version:"23.100.0.4"
Index:"0000"
INF:"oem115.inf"
INF Section:"Install_GEN_QSR_HrP2_201_AX_2x2_WinT"
Installed:"Yes"
IP Address:"192.168.12.145;fe80::6a88:c611:d7cb:dee7;2607:fb91:8b96:d0bb:f0bd:1e39:a882:87f7;2607:fb91:8b96:d0bb::f2ac;2607:fb91:8b96:d0bb:f263:8d57:e575:f35f"
IP Subnet:"255.255.255.0;64;128;128;64"
Last Reset:"01/22/2025 01:33 AM"
MAC Address:"58:6C:25:B0:A7:9D"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{6FAD7C76-3120-43DF-917D-5581850F9D61}"
Network Name:"TMOBILE-D9F0"
Network Type:"Infrastructure"
PNP Device ID:"PCI\VEN_8086&DEV_A0F0&SUBSYS_00748086&REV_20\3&11583659&2&A3"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Power Management Supported:"No"
Product Type:"Intel(R) Wi-Fi 6 AX201 160MHz"
Profile:"TMOBILE-D9F0"
Radio Type:"802.11ax"
Receive Rate:"865 Mbps"
Service Name:"Netwtw10"
Signal Strength:"85%"
State:"connected"
Status:"Enabled"
Transmit Rate:"613 Mbps"
Type:"Ethernet 802.3"
- "Service Bindings"
Bridge Driver:
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
Nested Network Virtualization:
QoS Packet Scheduler:
- "Settings"
*DeviceSleepOnDisconnect:Sleep on WoWLAN Disconnect:"Disabled (0)"
*PacketCoalescing:Packet Coalescing:"Enabled (1)"
*PMARPOffload:ARP offload for WoWLAN:"Enabled (1)"
*PMNSOffload:NS offload for WoWLAN:"Enabled (1)"
*PMWiFiRekeyOffload:GTK rekeying for WoWLAN:"Enabled (1)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
ChannelWidth24:Channel Width for 2.4GHz:"Auto (1)"
ChannelWidth52:Channel Width for 5GHz:"Auto (1)"
CtsToItself:Mixed Mode Protection:"RTS/CTS Enabled (0)"
FatChannelIntolerant:Fat Channel Intolerant:"Disabled (0)"
IbssTxPower:Transmit Power:"5. Highest (100)"
IEEE11nMode:802.11n/ac/ax Wireless Mode:"4. 802.11ax (3)"
MIMOPowerSaveMode:MIMO Power Save Mode:"Auto SMPS (0)"
RoamAggressiveness:Roaming Aggressiveness:"3. Medium (2)"
RoamingPreferredBandType:Preferred Band:"1. No Preference (0)"
ThroughputBoosterEnabled:Throughput Booster:"Disabled (0)"
uAPSDSupport:U-APSD support:"Disabled (0)"
WirelessMode:802.11a/b/g Wireless Mode:"6. Dual Band 802.11a/b/g (34)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Home"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"16.06 GB"
Physical Memory (Available):"0.75 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.26100 Build 26100"
Virtual Memory (Available):"10.04 GB"
Virtual Memory (Total):"23.83 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5049622:"Update [1/16/2025]"
KB5050009:"Security Update [1/16/2025]"
KB5050387:"Security Update [1/16/2025]"
- "Processor"
- "11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 140 Stepping 1"
- "Chipset Name":"11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=11th+Gen++Core+i5+1135G7+"
CPU Speed:"2.42 GHz"
Current Voltage:"9. volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 AM"
Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.2454"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"4 x 192 KB"
Level 2 Cache:"4 x 5120 KB"
Level 3 Cache:"8 MB"
Load:"84%"
Manufacturer:"GenuineIntel"
Model:"140"
Name:"11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz"
Number of Cores:"4"
Number of Cores Enabled:"4"
Number of Logical Processors:"8"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000806C1"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"1"
- "Storage"
- "NVMe WDC PC SN530 SDBPNPZ-512G-1006"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"NVMe WDC PC SN530 SDBPNPZ-512G-1006"
Cylinder - Total:"62260"
Description:"Disk drive"
Driver Date:"06/21/2006 12:00 AM"
Driver Version:"10.0.26100.1150"
Error Code:"Device is working properly"
Firmware Revision:"HPS2"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"SCSI"
Manufacturer:"(Standard disk drives)"
Model:"NVMe WDC PC SN530 SDBPNPZ-512G-1006"
Partitions:"3"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_WDC_PC_SN530_SDB\4&395D9D14&0&020000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
SCSI Bus:"2"
SCSI LUN:"0"
SCSI Port:"0"
Sectors - Per Track:"63"
Sectors - Total:"1000206900"
Serial Number:"E823_8FA6_BF53_0001_001B_448B_48F5_AAFE."
Size – Available:"41.45 GB"
SMART Attributes:"Self-Test: 0 minutes, OK, Short Self-Test: 0 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"15876300"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Serial Number:"72750C8A"
Volume Dirty:"No"
- "SMART"
0x05 Reallocated Sector Count:0:"0"
0x09 Power-On Hours:4549:"0"
0x0C Power Cycle Count:546:"0"
0xAE Power-off Retract Count:46:"0"
0xBB Uncorrectable Error Count:0:"0"
0xBE Temperature - Current:56° C:"0"
0xBE Temperature - Highest:Not Available:"0"
0xBE Temperature - Lowest:Not Available:"20"
0xE8 Available Reserved Space:0:"5"
0xF1 Total LBAs Written:188592360:"0"
0xF2 Total LBAs Read:593270784:"0"
...#SSU#...
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is today's XP ]
RobbieR_Intel
Hello Cidney,
Thank you for reaching out regarding the issue you're experiencing with Intel Graphics Software.
To better assist you, kindly answer the following questions:
  • What is the game that you have tried to play?
  • What is the game platform you're using to play it?
  • Do you have any other software that manage the graphics of your system?
  • Where did you download the Driver?
  • Have you performed a BIOS update?
I look forward to your response!
Robbie R.
LucasGouvêa
Olá, estou com o mesmo problema, pode me ajudar? No assistente mostra tudo atualizado, mas no centro de comandos diz não estar.
Cidney
Sorry for being a day late
Here are my responses to your questions:
1. Persona 5 Royal, but that got better when I shut my laptop off for the night and tried again in the morning.
2. Steam.
3. There is the graphics figure already in Windows, though I'm not sure if that really works or not.
4. Where I normally do. Intel® Driver & Support Assistant.
5. YES! I went through the hassle of looking how to update my BIOS for this. When I updated my computer, I checked the Intel Graphics Software app and IT STILL SAYS I'm incompatible.
Cidney
On second thought, I checked my BIOS because a graphic update came and it's back to the previous version.
RobbieR_Intel
Hello Cidney,
Thank you for answering the following questions, and for sharing an update regarding your Intel Graphics Software. With that being said, do you still encounter any issues as of the moment?
Robbie R.
Cidney
Well, I did the graphic update. And Graphic Command Center is up and running again! My BIOS is still the same...but that's fine with me. I just wanted my command center back, so I could play games that required higher graphics. I only touched BIOS because I thought I had to.
But thanks for talking with me about my issues.
It works againIt works again
rolybaba
Hello, Cidney
I have the same problem, and I’ve tried many things, but none of them worked. My drivers seem up to date, and I couldn’t find a solution to this issue. Could you explain how you solved it? How did you update your graphics driver?
Thanks for your time.
Tharusha_444
i also had the same issue after i played a game on steam today.
Cidney
Um, hello, I can't say if this is a complete fix: but something I've been doing is let the normal download go (the one Intel® Driver & Support Assistant gives you).
For me, it works for a day but if it goes incompatible the next, download it manually. Typically, it worked.
I think you have to do both (there was this one time I just did the manual download, and it sadly still became incompatible. So, I did the normal download afterwards, and it worked. This is just what works for me though, let me know if it works for you.
RobbieR_Intel
Hello Cidney,
Thank you for your response. I'm glad that Intel Graphics Software is working on your system again. However, I would like to confirm if you are referring to the Intel Graphics Command Center (IGCC) for the one that you would like to access. As the Intel Graphics Command Center and Intel Graphics Software are two different applications.
If not, may I know if you need further assistance? I look forward to your response!
Robbie R.
RobbieR_Intel
Hello Cidney,
I wanted to check if you had the chance to review the information I posted. May I know if you still need further assistance?
Robbie R.
RobbieR_Intel
Hello Cidney,
Robbie R.
JackJohn
Hello, I have a problem with the Intel Graphics Software application. It used to work, but sometimes it stopped connecting to Intel, showing me the message "The current system configuration is not supported by Intel Graphics Software". Now this message does not go away.
