Hi everyone,
I have an optimus laptop with an Intel HD 4600. For those who don't know what that means, it means that while I have a dedicated graphics card (a 970m) all of the outputs are wired to my integrated card to allow the laptop to turn off the dedicated one when it is not needed. I am looking to purchase a 144Hz monitor and just wanted to double check whether the Intel HD 4600 supports 144Hz output. According to the quick reference https://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics here the intel hd 4600 can support :
DisplayPort* 1.2 / eDP*
H-Processors: 3840 x 2160 @ 60 Hz (Ultra-HD)
I have a mini DP on my laptop, and an HQ processor, and was curious as to whether this meant that throught the mini display port (and likely a mini DP to DP adapater) it would be possible to run 1080p at 144 / 120 Hz.
OfficialPiAddict
- Tags:
- Laptops
Hello OfficialPiAddict,
The bandwidth needed for 1080p@144 is roughly 8.96 Gbps based on this link http://k.kramerav.com/support/bwcalculator.asp http://k.kramerav.com/support/bwcalculator.asp. You will need to have DP 1.2 in your configuration, and by this I mean your graphics output, cable and the input of your T.V must be DP 1.2; so, in theory with this configuration you will be able to achieve it. However, before purchasing the TV, my recommendation is since you have a laptop you could take it to the store and see if you can achieve it, if possible do as much testing in order to check that resolution is possible.
Amy.
I am following up your thread, if there is something else I can help you with, please let me know.
Amy.
Hi Amy,
Thanks for answering
I just had one more question, would it also be able to output at the same resolution (and refresh rate) using DVI-D (converting Mini DP to DVI-D) if the monitor did not have a display port?
OfficialPiAddict
Just straight connections, bear in mind that your graphics output, cable and the input of your T.V must be DP 1.2.
Amy.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
