Hello, I was directed to create a new thread based on
here is the information requested in that thread.
Category
Questions
Answers (N/A if not applicable)
Description
Screen flickers when connected via displayport but not vga, moninfo tool shows monitor as connected via displayport even when connected with vga cable.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): x
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
HP Prodesk 600 G2 SFF
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
onboard graphics only
Make and model of any Displays that are used to see the issue <strong style="font-styl...
Hello mllewellyn,
Thank you for joining Graphics community.
Let's try with the following, let's update the following drivers;
- Driver for your monitor, go to "Support & Downloads"; http://www.viewsonic.com/us/vg2439smh.html ViewSonic VA2439Smh, 24 Monitor
- BIOS HP Business Desktop ME 11.x Firmware
- Intel Chipset Support for Windows
- Intel Management Engine Driver
- Intel Graphics Driver - 64b
Find these here; http://support.hp.com/us-en/product/hp-prodesk-600-g2-small-form-factor-pc/7633319/drivers HP ProDesk 600 G2 Small Form Factor PC Drivers and Downloads | HP® Customer Support
How many DP cables have you tested?
Amy.
mllewellyn, were you able to follow my suggestion?
Amy.
Sorry for the delay I've been waiting on some new cables suggested by HP,
I haven't had any success, I had an HP support rep take a look at the computer also and we've updated all the drivers and the bios you've listed, I'm actually using a newer bios than you have in your post. I've tried 3 different cables and I've also tried on different monitors with the same results.
Thank you for that information.
Please let me know as soon as you get the new cables.
Amy.
I tried the new cables sent by HP and I am having the same results.
mllewellyn, I would like to know; what did HP say about this issue? Do they think is hardware or software related?
Amy.
At this point they are not sure, but since we have tried all other options I'm thinking it's hardware related. I do not have this issue on any pc that does not contain an HD 530 graphics chipset.
That is also my thinking, that is why I asked that. Just like mentioned, none of my Intel® HD Graphics 530 systems behaves likes this; they are working fine.
Amy.
I'm having this issue specifically when I'm working on excel it flickers from time to time.
The description of my computer is the following:
HP Pro One 600 G2 21.5-in Non-Touch AiO
Intel HD Graphics 530
Intel Core i5-6500 CPU @ 3.20 Ghz 3.20 Ghz
Hello FSA5,
For us to further assist you and to help you with the specific problem, please create a new thread, make sure to add all the details in regard to your system. This way the next agent will have a better look at your specific scenario, you can add this thread as a reference but I recommend creating a new thread in order to isolate your case.
Amy.
