23088 Discussions
Intel HD Grafiks 4000 Treiber
xsela
Hello , i have a question.
I want to Update my old Graphics Driver and have some problems.
I downloarded 5 Versions from Intel and nothing can be installed.
Can someone help me pls ? i Dont know what to do
Thx
Hi Omerta212,
Sure, I will help you. Please run our Intel® System Support Utility and send me the results of the test. It is necessary to narrow down the issue and collect system configuration first.
Intel® System Support Utility, Version: 2.0
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Mike C
Hi Omerta212,
Pre-build systems usually run customized drivers by system manufacturers. They customize our drivers available with Intel® Driver Update Utility.
Additionally your system has hybrid graphics, the Intel® graphics driver works together with the AMD HD 7670M. I suggest you to install the latest drivers available at Samsung website.
Samsung Notebook Serie 3 350E7C S0M
http://www.samsung.com/de/support/model/NP350E7C-S0MDE http://www.samsung.com/de/support/model/NP350E7C-S0MDE
Mike C
xsela
Hey ,
I downloarded 2 Things.
The left side doenst work , because of the mistake.
Translated like :
your system not satisfied minimum requirement
The Chipset on the right side was successfully
http://postimg.org/delete/w2t04qqb6/ http://postimg.org/delete/w2t04qqb6/
Hi Omerta212,
The driver that you was trying to install belongs to Windows® XP. If you have a newer operating system it will be necessary to contact Samsung and request a newer driver or use the generic driver provided with your OS.
Mike C
