23280 Discussions
Intel HD Graphics 4000 driver for win10 x64 does not work!
yy3
My graphics driver version is pictured above,but it is working abnormal,Every time i reinstalled the graphics driver,it can work 1-2 hours normal, and then online and offline video are stuck can not be seen,can not play games, the only effective way is to reinstall the driver,I'm almost bored to death. who can help me, thank you very much, my system info and graphics info as follows:
System Information
Time of this report: 3/12/2016, 18:05:41
Machine name: FOREST_LAPTOP
Operating System: Windows 10 专业版 64-bit (10.0, Build 10586) (10586.th2_release_sec.160223-1728)
Language: Chinese (Simplified) (Regional Setting: Chinese (Simplified))
System Manufacturer: LENOVO
System Model: Lenovo U310
BIOS: 65CN99WW
Processor: Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz (4 CPUs), ~1.8GHz
Memory: 4096MB RAM
Available OS Memory: 3954MB RAM
Page File: 2465MB used, 2193MB available
Windows Dir: C:\Windows
DirectX Version: 11.2
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10586.0000 64bit Unicode
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_390317AA&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO102C
Native Mode: 1366 x 768(p) (60.097Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.4358 (English)
Driver Version: 10.18.10.4358
DDI Version: 11.2
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 2015.12.21 AM 12:00:00, 10948400 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-1C65-0919B4C2C735}
Vendor ID: 0x8086
<span style="color: # ff660...
IUman
Hello yyw02110217,
Thank you for joining the Intel communities.
Try uninstalling the driver and then reinstall it, if this does not solve your problem I strongly recommend installing the latest validated driver from your computer manufacturer website or check the manufacturer's support website for updated system BIOS, drivers, and solutions to common problems..
Note: Once you install the "Intel generic" driver you will overwrite any customizations your system manufacturer made to the driver specific for your system model.
Best wishes,
Ivan
yy3
Thank you very much for your reply,Maybe updated system BIOS can solve this problem,i `ll try it !
IUman
Thank you for your time and if you update the BIOS please let us know how it goes.
yy3
Ok,after a lot of time to reinstall system, i found what caused the problem was not graphics driver and BiOS, it was my Audio driver.
i uninstalled the latest Audio driver and then installed an old version Audio driver download from my computor manufacturer's support website.
the problem for a long time was solved.
I'm glad that your issue has been resolved and we really appreciate you have taken the time to share with us how you were able to solve the problem.
