23812 Discussions
Intel HD Graphics 530 Crash OPENGL
JTOLE1
I have a DELL computer with Intel(R) HD Graphics 530.
And i develop a 3D application which use opengl. This applications works on other computer but crash on computer with integrated Graphics like HD530.
glGenBuffer() =>
WindowsError: exception: access violation writing 0xFFFFFFFFC7013EA0
--- OPENGL INFOS --- Vendor: Intel Renderer: Intel(R) HD Graphics 530 OpenGL Version: 4.4.0 - Build 21.20.16.4821 Shader Version: 4.40 - Build 21.20.16.4821
I tried to upgrade my hd drivers with the last, but i keep the same error and i still in OpenGL 4.4.0. Is it possible to pass at OpenGl 4.5.0 with this hardware?
best regards
Thank you very much for taking the time to reach the Intel Communities Team, Jeyrozus. I will do my best to assist you further.
Firstly, allow me to share with you that the maximum OpenGL* supported version will be defined by the processor. You can double check that if you go to https://ark.intel.com/ ark.intel.com and search for your processor model. The hardware will not allow you to update to a higher OpenGL* version than the one listed on the specifications of the processor.
Then, you can reach our https://software.intel.com/en-us/home Intel® Developer Zone team so they can help to develop your 3D application.
Antony S.
JTOLE1
I followed your adived and my processor is : https://ark.intel.com/fr/products/88196/Intel-Core-i7-6700-Processor-8M-Cache-up-to-4_00-GHz Caractéristiques du produit Intel® Core™ i7-6700 Processor (8M Cache, up to 4.00 GHz)
So in theory i can go to opengl 4.5 but i dont know how , because when i download the last drivers in DELLwebsite he installed the 4.4 version. If i download the drivers via INTEL platform he says that is not compatible with my configuration... so i'am a little confused in how to upgrade to the opengl 4.5
VARADHARAJAN
Valued Contributor II
recently intel released the latest graphics driver 24.20.100.6136 for windows 10 64bit for intel HD graphics 530
here is the link
https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530 Downloads for Intel® HD Graphics 530
uninstall the previous installed driver with REVO UNINSTALLER and then restart the computer
after that install the new graphics software or driver
JTOLE1
VARADHARAJAN
Latest version is 15.45.23.4860 , this version supported windows 7 64bit and 8.1 64 bit also
for normal version here is the direct downloading link in .exe
https://downloadmirror.intel.com/27360/a08/win64_15.45.23.4860.exe https://downloadmirror.intel.com/27360/a08/win64_15.45.23.4860.exe
for IT professional or developer version here is the direct downloading link in .zip
https://downloadmirror.intel.com/27360/a08/win64_15.45.23.4860.zip https://downloadmirror.intel.com/27360/a08/win64_15.45.23.4860.zip
I hope , with this reply , your graphics problem will be solved
