- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi! when I run http://muonline.webzen.com/ Muonline seems to run fine but doesn't display health globes or skill bar and inventory windows are transparent is this.
I downgraded graphics driver to all older versions and still same problem. What happening? How to solve?
Laptop - Core i3-7100U with Intel HD Graphics 620 only and windows 10 64 bit
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi taidoan,
I understand the game Muonline does not display healthy globes, the skill bar and the inventory.
I would like to replicate this issue but I will need additional information about this matter, please fill out the following form as complete as possible.
/thread/77761 https://communities.intel.com/thread/77761
Looking forward to hearing from you.
Allan J.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Allan! Please refer to the following and attachments for more info. Thank you!
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Acer Aspire E5-575-359T
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
N/A
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)EFP = External Flat Panel (Monitor you plug in)
LFP
How much memory [RAM] in the system (see note2 below).
4 GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc <p style=...
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi taidoan,
Excellent information, thank you for taking the time and send the report. I will work on this matter and update this thread as soon as I get more information about it.
Allan J.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi taidoan,
Thank you for reporting this matter. I am currently reviewing this issue. This thread will be updated as news become available.
Allan J.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Solved the problem?
i have this problem too
please help me
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
and i think never be solved.
if u solved this problem another way plz post .
thanks
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
hi taidoan i have the same processor as you and the same problem. ¿They solved your problem?
Leonardo
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
no man, not solved
the better way its buy a offborad video .
the intel and webzen never will solved this.
GL
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Yes friend; I'm already thinking of investing in an external video card unfortunately. they will not give us any solution.
good luck for you too
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Everyone,
I would like to confirm that Intel is investigating this issue, and an internal bug has been filed [Bug ID 1406478036]
This issue is currently under debugging, thus as soon as I have more information I'll post it here.
Thank you for your patience.
Kindest Regards,
Ronald M.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
many thanks Ronald; surely we will be attentive to a possible solution.
I appreciate your response.
best regards
Leo
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello all,
I got results back from our debugging team. They did some debug tracing and noticed that the game is not loading methods (highlighted in red) that are required to set transparency, which suggest the issue is coming from the game itself and not from the graphics driver:
00000114 160.67968750 [6708] _level0.scene.onLoad()
00000115 160.69337463 [6708] Error: Can't find method '_level0._root.scene.SetScale' to invoke.
00000116 160.70703125 [6708] Error: Can't find method '_level0._root.scene.SetVisible' to invoke.
00000117 160.72071838 [6708] g_mcRuudShopFrame
00000144 161.29759216 [6708] g_mcRoundCount
00000145 161.30567932 [6708] gProgressFrame
00000146 161.31597900 [6708] Scale9Grid has negative width -0.100000
00000147 161.38458252 [6708] Error: Can't find method '_level0._root.scene.SetScale' to invoke.
00000148 161.38708496 [6708] Error: Can't find method '_level0._root.scene.SetAlign' to invoke.
00000149 161.57159424 [6708] [MakePII] Acquire alternative PII(1)
00000150 161.57170105 [6708]
00000151 346.47653198 [6708] _level0.g_mcHeroPosition._helpBox.setCharLevel(3)
00000152 348.13128662 [6708] _level0.g_mcHeroPosition._helpBox.setCharLevel(3)
00000171 349.87506104 [6708] create.. icon_portal- : Devias Entrance
00000172 349.87521362 [6708] create.. icon_portal- : Noria Entrance
00000173 349.87539673 [6708] create.. icon_portal- : Valley of Loren Entrance
00000174 377.80490112 [6708] Error: GetVariable failed: can't resolve the path "_level9999.RemoveInputWindow"
00000175 377.80490112 [6708] Error: Can't find method '_level0._level9999.RemoveInputWindow' to invoke.
Before sending the debug info to the game developer, can someone using 6th Generation Graphics (also known as Skylake) confirm if the issue occurs on Windows 7 or Windows 8.1?
Ronald M.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Well Ronald thank you very much for the information. Send ticket to the game to find a solution.
I have an ASUS i3 7th gen 7100 laptop with intel hd graphics 620 and windows 10 64bits.
I appreciate your concern.
Greetings from Cordoba Argentina.
Leonardo Bulacio
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Ronald!
Thanks so much for your support!
Many people also have similar problems with HD graphics http://forum.webzen.com/forum/en/mu-online-english/mu-online-issues-feedback/2244303-problems-with-graphics-solved-windows-10 5500, http://forum.webzen.com/forum/en/mu-online-english/mu-online-issues-feedback/1314324-graphics-issue 6100, HD Graphics http://forum.webzen.com/forum/en/mu-online-english/mu-online-issues-feedback/1038619-my-hud-is-transparent-possible-solutions-to-graphics-issues/page4 520, 530, 620
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Ronald,
I did some research and found that GL_ARB_fragment_program and GL_ARB_vertex_program extensions are causing this issue. If I set only GL_ARB_fragment_program at GL_EXTENSIONS, the problem disapear, but when I set both, the problem shows up. Ofcourse that I had to hook glGetString() to manipulate the output list.
Can you forward it to your debugging team? I pretty sure that is a Intel driver issue, cause both AMD and nVidia have theses extensions seted, with no transparency bug at all.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
If I have a problem with an online game called DarkMu this when connecting to the server, many of the options appear in transparencies I have a 7th generation Icore 3 with HD 630 graphics I have tried all possible configuration and I have not been able to fix the problem , but in my laptop with a third generation Icore 5 with HD 4000 graphics I do not have that problem could help me solve this problem
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi IsaacN,
Thank you for your feedback.
Can you please include the https://www.intel.com/content/www/us/en/support/articles/000022556/graphics-drivers.html DxDiag.txt report of both laptops? (i.e. the HD Graphics 4000 laptop and the HD 630 laptop)
Please also let me know the link where we can download this game (just in case it is a variation of MU online http://muonline.webzen.com/download/game-download MU Online | Medieval Fantasy MMORPG).
Ronald M.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Well I clarify the machine with HD graphics 4000 is a laptop and the machine with HD graphics 630 is a desktop computer. Both with windows 10 and the updated drivers, later I will get the DirectX reports from both computers.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
