23469 Discussions
Intel HD Graphics 630 dual output not working
Jmoreira
I have an intel NUC with the following setup
Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz 3.10 GHz
RAM  16,0 GB
I am running Windows 11 Home but i have the same issue with windows 10...
The Graphic board is Intel HD Graphics 630m
The version of the Graphic Driver is 30.0.101.1191.
I have two HDMI outputs /one in the front and one in the back / and two mini dp on the NUC.
When I connect the two HDMI to two screens only one is displaying.
Windows is not able to detect the second screen.
I tried to use the Intel Graphics command center but without sucess no screen is detected ...
Please check the attached files.
Can you please let me know how to have the two screens?
megan3000
Valued Contributor I
What is the model of your nuc? Run this report, change from summary to detailed view and save the file as a txt file, then upload it to your reply (don't use the option to submit/send the report, it doen't work...)
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
DeividA_Intel
Hello Jmoreira,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Provide the Report for Intel® Graphics Drivers:
3. What is the brand and model name of the monitors used?
4. Was this configuration/setup working before? If so, when did the issue start?
Deivid A.
DeividA_Intel
Hello Jmoreira,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Jmoreira,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
