22949 Discussions
O Driver de Vídeo Parou de responder e se recuperou
Gabriels47
Tenho um Computador com um I5 2310 e 4GB RAM e sempre que eu vou abrir um jogo ou um programa que utilize dos Gráficos Integrados do processador, a tecla pisca em preto, fecha o app ou o jogo que eu abri e aparece a seguinte mensagem : O Driver de Vídeo Parou de Responder e Se Recuperou;
Eu já formatei o computador para Windows 7, 8, 8.1 e 10 porém o erro persiste.
Eu já desinstalei e instalei todos os Drivers de vídeo tanto da Intel, quanto da Positivo (fabricante da placa mãe) e não resolveu.
Já troquei a Bios do computador para a ECS e não resolveu.
Já troquei a pasta térmica do processador, não resolveu.
Troquei a fonte de alimentação, não resolveu.
Gostaria de saber se meu velho amigo tem salvação, ou é algo que não tem concerto nenhum.
n_scott_pearson
Intel has never supported your processor's graphics engine being used with Windows 10 and does not provide a driver supporting this configuration. As you have discovered, there are many issues with the compatibility driver that was provided by Microsoft. Quite simply, it was never intended to support gaming.
You can report your problem to Microsoft, but likely they will ignore the report. Really, your only options are to (1) if supported, add a PCIe NVIDIA/AMD graphics card, or (2) upgrade your entire system to something more modern (it is 12 years old).
Sorry there isn't a better answer, reality bites,
AndrewG_Intel
Hello @Gabriels47
We hope that the assistance provided by the community has been helpful.
We would like to inform you that due to the Intel® HD Graphics 2000 has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
Note: You might need to search for the proper Product Category and click on its "Show more" link if the product is not visible in the top rows.
Andrew G.
