23784 Discussions
Intel HD Graphics Driver Update Problem
Hello everyone,
I tried to update my Intel HD Graphic driver to the 15.28.15.64.3062 version that came out 03/21/2013 and I'm pretty sure I don't have that version.
I downloaded the zip and the exe version but in both case it showed me the same error message:
"this computer does not meet the minimum requirements for installing the software"
I checked and I do have all the requirements that are written in the "Installation_Readme" file. I'm only not sure about the third condition which is:
"There should be sufficient hard disk space in the directory on the system in order to install this software" because I don't know where to find
that information but i think I have space because I have about 20 GB free on my C/ disk.
These are my computer information:
Computer : Toshiba Satellite L655 PSK1EE
Processor : Intel(R) Core(TM) i3 CPU M370 @2.40GHz
System type : 64-bit Operating System
Windows Edition : Windows 7 Home Premium 64 bit
If it's not enough just tell me what to add and how to find the information about it.
Thanks For Your Help!
Kevin_M_Intel
Hi Shahnank,
Please open a new thread on the link below for us to assist you in the best way:
/community/tech https://communities.intel.com/community/tech
FNur
um i can't describe so i'm just going to display the picture
tried to install this :
got this notice :
my cpu system :
NJova
Hi
I have Toshiba Satellite c660 windows 7 professinal 32 bit.The problem is when i wanna try automatic update on Intel Corpotration Display-Intel (R) HD Grapshics Family it says failed.I try everything,driver genius end stuff like that.But it would not update.Can anyone help me.
Tnx!
King regards!!!
Sorry for my bad english
Kevin_M_Intel
Hi Timbic,
Please install the driver at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23376 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23376
If you are having problems to install this driver, please try with the manual driver installation:
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
If the problem persists, please try the driver provided by Toshiba that has been specifically designed for your computer.
CTara
I am having the same problem, i can't update my Intel HD Graphic driver
I have tried to use a multitude of the downloads but none seem to be working they all pop up with the same error message: "this computer does not meet the minimum requirements for installing the software" Here are my computer's specs:
Operating System: Windows 7 Premium 64-bit
System Manufacturer: ACER
System Model: Aspire M3985
Processor: Interl(R) Core(TM) i5-3450 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
Memory: 8192 MB RAM
Display
Name: Intel(R) HD Graphics
Manufacturer Intel Corporation
Chip Type: Intel(R) HD Graphics Family
DAC TYpe: Internal
Thanks for your time and assistance!
HFrit
Hi Kevin,
Would you be able to take a look at my computer's graphics and let me know a way I can upgrade the driver? I have tried to DL the latest and of course I do not meet the system requirements. I have an HP Pavilion laptop 2009
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.130318-1532)
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion dv6 Notebook PC
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz (2 CPUs), ~2.2GHz
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
Display Memory: 1695 MB
Dedicated Memory: 64 MB
Shared Memory: 1631 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LP156WH2-TLQ1
Monitor Id: LGD021B
Native Mode: 1366 x 768(p) (59.636Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.1808 (English)
Driver Version: 8.15.10.1808
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 6/3/2009 11:16:00, 5613568 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6902-11CF-9C74-2D16A7C2C535}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x3627103C
Revision ID: 0x0007
Driver Strong Name: oem3.inf:Intel.Mfg.NTamd64:iCNT0:8.15.10.1808:pci\ven_8086&dev_2a42
Rank Of Driver: 00E62001
HFrit
sorry forgot DAC is Internal...if that helps
Kevin_M_Intel
victor90,
Please disconnect the graphics card you have in the system and then try installing the driver at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405
If you get a notification message during the installation, I recommend trying the manual driver installation. Here are the steps:
Fransua63,
In your case, I recommend you to uninstall the current driver by doing the instructions at the following link:
http://www.intel.com/support/graphics/sb/CS-034574.htm http://www.intel.com/support/graphics/sb/CS-034574.htm
After that, download and install the latest driver at the following link:
If during the installation you get a notification/error message try the manual driver installation. Here are the steps:
HDK123,
I recommend you installing the latest driver for your controller. Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167
In case
When installing the drivers and following all these steps the issue persists, I recommend you contacting the computer manufacture for them to provide the driver specifically designed for the computer.
JKoni
Hey Kevin,
I have similar problem with mine computer in this specs:
Operating System: Windows 8.1 Pro 64-bit
System Manufacturer: Dell
System Model: Dell Vostro 3300
Processor: Intel(R) Core i3-370m
Physical Memory: 7990 MB
Display Devices
Card name: Mobile Intel(R) HD Graphics
Minimal Graphics Memory: 32 MB
Maximum Graphics Memory: 1696
Graphics Memory in use 103 MB
Driver Version: 8.15.10.2900
Operating System (6.2.9200)
DirectX Version 10.1
Kevin_M_Intel
Jakubk, the latest driver we have for your graphics controller is for Win 7 only. Since you have win 8.1, my best recommendation is to contact the Computer Manufacture so they can provide the drivers for your system.
JKoni
So i guess there's no newer than my actual driver because DELL.com doesn't provide any other. I thought you (intel) suppose to care about drivers to yours processors with newest os, which you also support. What a shame:(
greetings from Poland!
CSerr1
Hey Kevin,
System Manufacturer: Samsumg Electronics
Processor: Intel(R) Core(TM) i7-3635QM CPU @ 2,40GHz 2,40 GHz
Installed memory (RAM): 8,00 GB (7,71 usable)
System type: 64-bit Operating System, x64-based processor
Computer: Computer Type ACPI x64-based PC Operating System Windows 8.1 Home Edition OS Service Pack [ TRIAL VERSION ] Internet Explorer 9.11.9600.16521 DirectX DirectX 11.0
Display: Video Adapter Intel(R) HD Graphics 4000 (2112 MB) Video Adapter Intel(R) HD Graphics 4000 (2112 MB) Video Adapter Intel(R) HD Graphics 4000 (2112 MB) Video Adapter NVIDIA GeForce GT 640M (1024 MB) Monitor Generic PnP Monitor
When I try to upgrade the driver downloading by the link (http://dlcdnet.asus.com/pub/ASUS/OCA/nb/Win8.1/Graphic/Intel/V10.18.10.3383_Win8.1_64.exe http://dlcdnet.asus.com/pub/ASUS/OCA/nb/Win8.1/Graphic/Intel/V10.18.10.3383_Win8.1_64.exe) that the Action Center recomends the message about the requirements appears.
Kevin_M_Intel
Jakubk, It is important to mention that we provide the hardware to Computer Manufacture and they will design and create drivers for their systems. So the limitations are set by the Computer Manufacture.
Carloscaires,
Did you try the steps provided above?
astor1
I cant seem to update my driver, the download service on the website wont work, and the manual download keeps saying not compatable (after the initial driver download). i have a 64 bit asus vivo book, it is running windows 8 and i have an intel hd 4000 on driver version 9.17.10.2867. my processor is an intel core i5-33117u with 6gb installed ram. this issue is making games like starmade and second life unplayable.
Kevin_M_Intel
Please try this driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714
In case you have a notification message during the installation, try with the manual driver installation steps provided above.
lmili
Kevin could you tell me which driver should i install cause i just can't find it?
Name: Intel(R) HD Graphics Family
DAC Type: Internal
Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz (4 CPUs)
DShyn
hi, sorry for my bad english, i'm french ^^
i have a problem when i try to update my intel graphics HD 4000: i choose the automatically update, it extract on my computer and then i have an error message: not compatible.
Product Detectedhttp://www.intel.com/support/graphics/intelhdgraphics4000 Intel® HD Graphics 4000Current Driver Installed10.18.10.3308Newer Driver Available:15.33.18.64.3496 (10.18.10.3496)
Download Now
File Size:140 MBhttp://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23714 Detailed Driver Description & Driver Documentation
this is current driver and the newer driver what i need.
my labtop is a windows 8.1
my processor: intel(r) core(tm) i3-3217u cpu @ 1.80 ghz
have you an idea or a fix?
thanks
Kaisoka
Kevin_M_Intel
TGawa
hi kevin. i tried the driver in my pc but the same error occured.your pc does not meet the minimum requirements..anyway thank you for looking into the matter.
these are some files that might help.
Kevin_M_Intel
Tush,
Thanks for the information. Have you tried the steps from this link?
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
TGawa
yup i hv tried the steps and still the error message occurs. i dont know what is the problem with my pc.
