23807 Discussions
Intel HD Graphics Driver Update Problem
Hello everyone,
I tried to update my Intel HD Graphic driver to the 15.28.15.64.3062 version that came out 03/21/2013 and I'm pretty sure I don't have that version.
I downloaded the zip and the exe version but in both case it showed me the same error message:
"this computer does not meet the minimum requirements for installing the software"
I checked and I do have all the requirements that are written in the "Installation_Readme" file. I'm only not sure about the third condition which is:
"There should be sufficient hard disk space in the directory on the system in order to install this software" because I don't know where to find
that information but i think I have space because I have about 20 GB free on my C/ disk.
These are my computer information:
Computer : Toshiba Satellite L655 PSK1EE
Processor : Intel(R) Core(TM) i3 CPU M370 @2.40GHz
System type : 64-bit Operating System
Windows Edition : Windows 7 Home Premium 64 bit
If it's not enough just tell me what to add and how to find the information about it.
Thanks For Your Help!
Kevin_M_Intel
Hi Aquaninja101/ stream1,
You can try the steps above with this graphics controller:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23714 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3720&DwnldID=23714
Tush,
If you have done the steps mentioned in the document mentioned above, I recommend you contacting your Computer Manufacture so they can provide the custom drivers designed and created specifically for your system.
DChen58
Umm....I cant download Intel(R) HD Graphic eversince i uninstall that driver from Device Manager.It will say 'My Computer Does Not Meet The Requirement To install this software'.I Used To Have That driver but why cant i now.I have all the requirement for the download.
Window 8/8.1 64bit,Intel Inside Core i5.
Kevin_M_Intel
Hi AbhiShah,
Thanks for the comments. Based on the system report you posted it seems your computer is running a second generation processor and that is the reason why you are having problems installing the driver Ver 3496. This version is for 3rd/4th generation processors.
The driver you need to install is the following:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3319&DwnldID=23763 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3319&DwnldID=23763
If you get the notifications "Your computer does not meet the minimum requirement for installing the software" It is because our drivers are generic software and the drivers that oems provide are special and custom drivers specifically for their systems. So in case you have problems try the steps mentioned here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Dawson5404,
I regret to say that I will need to know the specific graphics controller you have so I can provide accurate information. Can you please post your graphics report here?
How to get it?
Graphics Report: Right click on desktop> Graphics Properties> Options> Drop down Menu> Information Center> Save> Open .txt file created> Copy/Paste here.
DChen58
Sorry Cant Find Graphic Properties after right clicking on my desktop.Currently i dont have any driver neither can i open my Intel(R)HD Graphic Control
Kevin_M_Intel
HI Dawson,
I see you are working this same issue in another thread. Please continue here:
https://communities.intel.com/thread/53099 https://communities.intel.com/thread/53099
Kevin M
PZ11
System Information
Time of this report: 8/18/2014, 17:42:23
Machine name: PATRICKSPC
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_gdr.140330-1035)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: K55A
BIOS: K55A.406
Processor: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz (4 CPUs), ~2.6GHz
Memory: 4096MB RAM
Available OS Memory: 3982MB RAM
Page File: 2350MB used, 5726MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_21021043&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD038E
Native Mode: 1366 x 768(p) (59.996Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3308 (English)
Driver Version: 10.18.10.3308
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 10/1/2013 13:02:32, 12100096 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-1F7F-0801B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x21021043
Revision ID: 0x0009
Driver Strong Name: oem20.inf:5f63e5341859ec8c:iIVBM_w81:10.18.10.3308:pci\ven_8086&dev_0166&subsys_21021043
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB
CSerr1
Hi Kevin,
Can't you just tell me what driver I need to install?
System Manufacturer: Samsumg Electronics
Processor: Intel(R) Core(TM) i7-3635QM CPU @ 2,40GHz 2,40 GHz
Installed memory (RAM): 8,00 GB (7,71 usable)
System type: 64-bit Operating System, x64-based processor
Computer: Computer Type ACPI x64-based PC Operating System Windows 8.1 Home Edition OS Service Pack [ TRIAL VERSION ] Internet Explorer 9.11.9600.16521 DirectX DirectX 11.0
Display: Video Adapter Intel(R) HD Graphics 4000 (2112 MB) Video Adapter Intel(R) HD Graphics 4000 (2112 MB) Video Adapter Intel(R) HD Graphics 4000 (2112 MB) Video Adapter NVIDIA GeForce GT 640M (1024 MB) Monitor Generic PnP Monitor
SRhei
Same thing but I have a WIndows 8 Asus with Intel core i7 4th gen Intel HD graphics family and was wondering what update driver I should use.
TWitt2
I am trying to find out the same answer as Aquaninja101. I will wait for the response from Kevin....thanks
MShaw6
I can't find the right update for my graphics intel drive
I went to choose 3rd generation Intel HD 4000 from the download page and choose windows 8 64 bit....It says that the latest version is 15.33.22.64.3621
But when I click on desktop>graphic properties then went the intel graphics control panel open I clicked on options and support >information center ....It says that my driver version is 9.17.10.2932
Which isn't starting with (15.33.22) AT ALL.
So when I started to download that driver from here :https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23885&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23885&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers
It gave me an error message says:The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer.Setup will exit
so I really needs ur help to successfully update my Intel graphics card
My laptop specification:
Lenovo Z500
Proccessor: Intel(R) Core(TM) i5-3230M CPU @ 2.60 GHz
Windows Edition : Windows 8 Pro
My intel graphics card is :Intel(R) HD Graphics 4000
I also got Nvidia Geforce 740M 2GB dedicated
Tell me if you wants any other specifications
Thanks alot guys for listening and for helping
Kevin_M_Intel
Hi SUPERMOST,
Please check post # 77.
Kevin M
JWu75
I recently tried to update my Driver to the "Intel® Iris™ and HD graphics Driver for Windows* 7/8/8.1 64-bit" Version 15.33.22.64.3621. Similar to the OP, I am 100% certain that I do not have this version for the driver, however, when I try to update my driver on the device manager page, it is constantly telling me I already the latest version. I am currently on version 9.17.10.2857, the Driver Date being 2012-09-13. When I download the driver from this page: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23885&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers Download Center. It says my computer did not is not compatible or something and the program will exit.
Is there any way to update my computer to the latest driver?
Here are my specs :
Windows 8
Manufacture : Samsung
Processor : Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
RAM: 8.00GB (7.89GB Usable)
System Type: 64 Bit operation system, x64-based processor
Current Driver Version: 9.17.10.2857
Storage Total size of hard disk(s)907 GB Disk partition (C:)742 GB Free (907 GB Total) Media drive (D:)CD/DVDGraphics Display adapter typeIntel(R) HD Graphics 4000 Total available graphics memory1664 MB Dedicated graphics memory32 MB Dedicated system memory0 MB Shared system memory1632 MB Display adapter driver version6.2.9200.16384 Primary monitor resolution1366x768 DirectX versionDirectX 11 or better
Any help is appreciated!
Kevin_M_Intel
Hi SnakeCity,
Have you tried the steps mentioned before on post # 77?
MMark34
Same problem,
I have re-installed my windows and I cannot install my graphic card. Got the message that this card is not supported.
System Information
Time of this report: 7/4/2014, 16:35:41
Machine name: MARKO-PC
Operating System: Windows 7 Home Basic 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
System Model: 350V5C/350V5X/350V4C/350V4X/351V5C/351V5X/351V4C/351V4X/3540VC/3
BIOS: BIOS_VENDOR Ver: P04AAL.022.120630
Processor: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3992MB RAM
Page File: 2231MB used, 5749MB available
Windows Dir: C:\Windows
DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_C0D8144D&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Monitor Id: AUO21EC
Native Mode: 1366 x 768(p) (60.063Hz)
Driver File Version: 10.18.0010.3621 (English)
Driver Version: 10.18.10.3621
DDI Version: 11
Driver Model: WDDM 1.1
Driver Date/Size: 5/16/2014 21:27:30, 16586584 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-D879-D2E0B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0xC0D8144D
Revision ID: 0x0009
Driver Strong Name: oem6.inf:IntelGfx.NTamd64.6.1:iIVBM_w7:10.18.10.3621:pci\ven_8086&dev_0166
Rank Of Driver: 00E62001
Please help.
MOcho2
I have a Mac Book Air 3 generation with Intel HD graphics, When I boot in Mac OS, all works fine, but when boot in Windows 7 with BootCamp, after "starting windows" it get a black screen, in safe mode works perfect, if I boot with a second monitor connected to my Mac its load all right, I update to the last driver version, but not fixed my problem, any suggestion?
Kevin_M_Intel
Miguel8a, I am sorry you are having this problem, you can try our driver but it is a generic driver and most of times it does not work correctly for Mac systems due to their internal hardware and software composition and limitations. I strongly recommend you contacting your Computer Manufacture for them to provide the special drivers you required.
Marko021,
The driver your system currently have is the latest one we have.
Kevin M
MOcho2
Hi Kevin, after many weeks in internet I found a page of apple with the last firmware for each model of Apple computer, I try to use Automatic Updates and all time Maveric OS say I have the last version, but in this page i found a newest, after update mi system with this firmware my problem was fixed
This is the link if somebody have the same problem
http://support.apple.com/kb/ht1237 http://support.apple.com/kb/ht1237
JYi3
I am having a similar problem with my installation/upgrade of my current video driver.
Here are my current specs on the driver
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600)
Processor: Intel(R) Core(TM) i5 CPU M 480 @ 2.67GHz (4 CPUs), ~2.7GHz
Chip type: Intel(R) HD Graphics (Core i5)
DAC type: Internal
Driver Version: 8.15.10.2900
RCust
Hello !
I've got same problem, and i try to download many drivers, but non of them work. So if you could please help to pick up a right one. Thanks a lot !
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: Slovak (Regional Setting: Slovak)
System Manufacturer: Dell Inc.
System Model: Inspiron N5110
BIOS: BIOS Date: 08/03/12 11:06:40 Ver: 04.06.04
Processor: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 CPUs), ~2.0GHz
Memory: 4096MB RAM
Available OS Memory: 4004MB RAM
Page File: 2757MB used, 5243MB available
Kevin_M_Intel
Hello Jakenardo,
Please note the latest driver we have for your controller is for Windows 7 and I noticed you have Windows 8.1. This may be the reason why you are having problems installing the driver(unsupported Operating System). My best recommendation in this case is for you to try getting the generic Microsoft driver for Windows 8.1 or downgrading to Windows 7 and installing the following driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22521 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22521
Mefi,
Try this driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764
If you find problems during the installation, try the steps mentioned here:
Kevin M
SChow3
Hi, I have a similar problem while using the intel driver update utility to see whether any update is available for the driver of my graphics card intel hd3000. It is showing that i have a generic intel driver and should contact the computer manufacturer. However i have installed the driver 9.17.10.3190 from lenovo official support website (mine is a laptop thinkpad e430 lenovo). Even the device manager says i have the correct driver and it is updated. Then why intel is showing this message while checking with driver update utility?
