I've updated my PC from windows 10 1803 version to 1809, after updating my PC to 1809 version the Intel Graphics drivers are not working and it shows an error with error code like this "Intel HD Graphics 4000 device driver has been blocked from starting Code 48".Can anyone help me out there.
链接已复制
I've downloaded the 15.33.47.5059 version what you have given in link.when i run the setup it's installing 10.18.10.5059 version only and its not at all installing the version 15.33.47.5059.I'm using intel i3-3220 CPU.
hey , Wanner .intel given exact link , he is right , both version are correct . let me explain
software version is 15.33.47.5059 , but the driver file version is 10.18.10.5059 .
you have already downloaded .exe file , use WinRAR extract file , open the graphics folder , find "igdlh.inf" find this line "
DriverVer=08/16/2018,10.18.10.5059" , you will to come know
I've actually had this exact same problem after installing this same update. It's very odd because I successfully installed the latest driver (10.18.10.5059), but I'm having the same Code 48 error. Any ideas of what to try? What do you mean "resetting" the PC? Did you roll back the update, skris19?
I think reset is the best option. I've contacted Intel and Microsoft customer care too they tried their level best but nothing has done, after reinstalling the window 10 1809 the problem has solved for me. why I'm telling to reset is because of some files won't be deleted after we upgrading our system to the newer version so the old files blocks some of the softwares and driver's. I've tried lot of troubleshooting nothing helped me after resetting,my PC came in to track.
I see. Thanks for the tip! I ended up with a temporary fix by rolling back the update, but that's not the best long term solution. I re-updated the driver to the latest version, and when I have time to work on it I'll try reinstalling the update and reset at that point if necessary. It's really unfortunate that this is happening. I hope Microsoft gets its act together a bit more with their updates so this doesn't happen again.
