23523 Discussions
Intel HD Graphics driver update posted for HD Graphics 2500/4000 (Ivybridge)
ROBERT_U_Intel
This update addresses several previously found issues. Please see the Release Notes excerpt below for details. As always, feedback is appreciated.
The 15.33.29.3945 has been posted to Intel Download Center at the following direct links to the drivers:
32-bit: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24328 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24328
64-bit: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24329 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24329
Wireless display connection might be lost while playing back video through Blu-Ray disk on a wirelessly connected display configured as extended desktop
Windows* 8
In Intel® Graphics Control Panel, the graphics power plans do not get updated when any of the already saved power plans are applied
Windows* 8
Some movie titles or video clips cannot be played back using Media Classic Player* on a wireless connected display using Intel WiDi™
Windows* 7
Resolved issue where DisplayPort* Audio is seen in Playback devices, after connecting the system through a DisplayPort to a display monitor that does not support audio output
Windows* 8.1, Windows* 7
Resolved issue of display corruption appearing on the screen while playing games that use DirectX 10*
Windows* 8.1
In some cases the display turned black, a few minutes after resuming from sleep
Windows
Robert
JWei10
Well, I was excited to see this. I had to re install everything on Laptop (Dell inspirion 15). And I ran everything I needed to be updated. Got everything updated, accept my HD Graphics Driver was out of date. I tried everything from the website. Nothing would work. I even tried to download the zips, exe's and nothing would work. it still said 9.7xxx etc. Well, I came across a post in these forums said Kevin_intel said too another person that was having the same issue. To delete the Driver itself. And then follow the link to the "Latest" update. So, I did as was told in the post. Now, when I go into device manager. Then go to my Intel(R) HD Graphics Properties, it says:
Driver Date 05/17/2014
Driver Version 10.18.10.3621
So since I noticed the first set of numbers is different. Even from where I took it from in the other thread. I do believe tho I read some where on here that, That is not a big deal, its the last 4 digits that show the current update. Which mine are different from the one mentioned in the OP. So, I am going to download the .EXE file from the link above. And see what happens! lol
EDIT-
WELL, it now shows the most current (Assuming I was right about the first set of Digits, and last set )
Wish I would of found this a few hours ago 😜
Thanks !
powerarmour
Valued Contributor II
Any reason why this driver doesn't support the Celeron J1800/1900 HD Graphics anymore?
Or rather why the latest Intel NUC driver is based on this release, yet doesn't support the Jxxxx series in the .INF
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24330 Intel® Download Center
ROBERT_U_Intel
@ Power armour,This driver was released primarily to address the issues mentioned above on the Intel HD Graphics 2500/4000. We have another driver release coming very soon that will support the Jxxx and Nxxx processors. Stay tuned.
Robert
EFish2
Do you plan on fixing the issue of being locked out of the overscan settings? I just purchased a Zotac CI320 (N2930) Nano and have terrible overscan in Win 8.1 and when I try to adjust the overscan I can't, The Intel Graphics Control Panel won't let me.
The odd thing is at the boot up screen it's formatted fine in 1080p/60Hz, but once I get into Windows I get tons of overscan. I have to run @ 1080i/30Hz to have no overscan.:( That's simply unacceptable for a HTPC.
GAida
Any upcoming drivers for Intel HD 3000?
ROBERT_U_Intel
@ Glen Aida, At this time there is not an update scheduled for HD 3000.
Robert
RA6
Robert,
With the last two diver updates the drivers have caused the Audio to go out. and the only way I am able to get the audio back is to restart the computer. Please fix this with your next divers update. also you have taken down the driver version that did work for my laptop. The driver version was the one before 15.33.22.64.3621 I have a window 7 64Bit computer
ROBERT_U_Intel
@ Rob A, The 15.33.22.64.3621 derivers are still available here: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23885&lang=eng&ProdId=3711 Intel® Download Center
Robert
RA6
I need the drivers that were before 15.33.22.64.3621 that is the only one that would work for me. either that or you guys need to fix this issue that the sound keeps going out and i have to reboot my system just for the sound to come back. Then it will go back out again. This issues is becoming very annoying. it is something to do with the Intel Audio drivers.
llybx
After testing out some driver versions, I noticed some performance regression on payday 2, 5-10fps difference compared to 3445. the performance seems starts to decrease on 3621.
and some graphical glitches too on payday 2. seems to be happening on every driver version.
https://dl.dropboxusercontent.com/u/119591896/pd2_intel/2014-10-09_00002.jpg https://dl.dropboxusercontent.com/u/119591896/pd2_intel/2014-10-09_00002.jpg
https://dl.dropboxusercontent.com/u/119591896/pd2_intel/2014-10-09_00005.jpg https://dl.dropboxusercontent.com/u/119591896/pd2_intel/2014-10-09_00005.jpg
Husendj
Intel HD 2500/4000 Graphics Driver version 10.18.10.5161 upgrade to windows 11 please
