23806 Discussions
Solidworks problem
Raiyan
I have Intel arc A750 graphics card. But it has a huge problem facing in solidworks.Gpu usage is too low and not constant. Lots of lags and slow performance may seen in Solidworks. Please fix this issue as soon as possible. Thanks.
Senkuchan
Valued Contributor II
I know that you have issues with solidworks and intel arc. Could you please tell me what steps you have taken to resolve this issue?
It is also possible that updating the driver to the latest version may help, as it may contain some fixes for the applications. You can find the link to download the latest driver here: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
If the problem persists, you can send us the ssu log so that we can investigate this further. The link to download the ssu tool is here: https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html
I’ve checked the solidworks website and noticed that arc A750 is not yet listed there. Here is the link: https://www.solidworks.com/support/hardware-certification/
To better assist you, could you please share more details about your issue, such as when it began, is this working fine before, and what changes occurred before this issue?
Senkuchan
ACarmona_Intel
Hello Raiyan,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
Eduardo_Ristow
Hi Raiyan,
The problem is Solidworks not enabling OpenGL by default for Intel GPUs, leading to all rendering being done by software by the CPU. Shocking, right?
It is an old issue that was never resolved. Also, it doesn't depend on the driver version, while the latest Intel ARC/Iris drivers corrected issues regarding OpenGL performance. Nevertheless, there is a workaround for this issue.
You have to open the Windows registry (win+r regedit), then navigate to:
Computer\HKEY_CURRENT_USER\Software\SolidWorks\SOLIDWORKS XXXX\Performance\Graphics\Hardware\Intel
, where XXXX is the year/version of your Solidworks, for example, SOLIDWORKS 2024.
You will find a REG_DWORD variable named Workarounds (funny, right?! A clear sign of excellent code quality); right-click it and select "Modify". Change the value from 10000010 to 10000009. Close the registry, launch Solidworks and enjoy.
zhuri
thanks!it done。
Ultra 9 285H /arc 140T
Willem-Waalre
Hi Zhuri, does Solidworks work flawless on the Arc? (After you changed the registry - see the above) Thank you for responding.
