22654 Discussões
Intel HD Graphics outdated or updated?
RAcil
Principiante
3.037 Visualizações
Hi, so I just installed the latest version for my PC with Intel Pentium G3240 (Intel HD Graphics), and now I updated it using the Driver Update Utility (Intel Driver Update Utility 2.0), but it still shows the old version (10.18.10.3960) instead of the newer once I installed (15.33.35.64.4176 (10.18.10.4176)). I used the Device Manager to view what version I currently have, which is still 10.18.10.3960, but when I use the Driver Update Utility to view the version, it is the latest one 15.33.35.64.4176 (10.18.10.4176). So my question is: Which one is the correct one? Have I updated my driver or is it still on the current version? Thanks.
Specs:
1 Solução
Jose_H_Intel1
Funcionário
2.170 Visualizações
Did the installer complete the process when you tried to install it manually? Did you find any errors?
https://downloadcenter.intel.com/download/24870/Intel-Iris-and-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit https://downloadcenter.intel.com/download/24870/Intel-Iris-and-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit
You may want to try the zip file installation method.
http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
Ver solução na publicação original
6 Respostas
Jose_H_Intel1
Funcionário
2.171 Visualizações
RAcil
Principiante
2.170 Visualizações
@joe_intel,
I do not know if the process completed... because when I clicked "Install", it just installs, then it requires reboot... then it rebooted, no errors found, except my problem (can't tell if it updated).
I'll try the ZIP file when I have freetime.... Anyways thanks
RAcil
Principiante
2.170 Visualizações
Jose_H_Intel1
Funcionário
2.170 Visualizações
Yes it is, look for your processor model in the table under Detailed Description.
Jose_H_Intel1
Funcionário
2.170 Visualizações
Were you able to update the driver version with either the exe installer or zip file method?
RAcil
Principiante
2.170 Visualizações
I somewhat installed it through Windows Update... and it seemed to install 10.18.10.4170...
I installed the ZIP method first, but after I installed it, the next reboot: I got BSOD, then reverted...
So I got 10.18.10.4170 update.
BTW Thanks
Responder
