23789 Discussions
Intel HD Graphics , windows 10 64-bit
narizpe
Hello, I recently uninstalled my graphics drive because it was giving my computer problems. I want to know how to reinstall a graphics driver that supports OpenGL so I can play Minecraft. My computer has already crashed once and I don't want that to happen again.
LeonWaksman
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan and save the results. The .txt file with the results please attach to your post.
Leon
narizpe
LeonWaksman
Its time to upgrade your hardware.
There is no Intel Graphics Driver to support Intel® HD Graphics 2000 on Windows 10.  The Graphics Driver version 9.17.10.4459 is the latest driver from Microsoft that supports your CPU and Windows 10.
The latest driver released by Intel is version 15.28.24.4229 and supports Windows 7 and 8 only.
Leon
narizpe
n_scott_pearson
You need to purchase an add-in PCIe graphics card and use that for your gaming and OpenGL software. You will have to stay with an older card, as modern cards are likely not supported by your motherboard's BIOS. I might suggest that you try using an NVIDIA GT 730, NVIDIA GT 710 or some other (older) NVIDIA card.
Hope this helps,
LeonWaksman
PCIe Graphics Adapter may be a good solution for you, however the 300W Power Supply in your PC, may be very marginal for this purpose. So, check the adapter power requirements.
Leon
n_scott_pearson
Yes, good point!
AndrewG_Intel
Hello @narizpe
Thank you for posting on the Intel® communities. We hope that the assistance provided by the community has been helpful.
Also, we would like to inform you that due to the Intel® HD Graphics 2000 has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
You can verify this product's discontinuance status at the following links:
Andrew G.
