22827 Discusiones
Intel Hades Canyon (NUC8i7hvk) HDMI overscaling
MSaey1
Principiante
2.829 Vistas
Hello
Where can I set the HDMI scaling in the Radeon Settings? There seems to be no option to set under- or overscaling issues ...
0 kudos
2 Respuestas
Empleados
1.512 Vistas
Hello Spacekiek,
Thank you for joining the Intel Community Support.
I understand that you would like to set HDMI Scaling in RX Vega M Settings. I would like to help you.
Please follow these steps:
1.Open Radeon RX Vega M Settings.
2.Select Display.
3.Select the scaling mode desired:
-Preserve aspect ratio
-Full panel
-Center
4.You can also move the slider to adjust the image.
Wanner G.
Empleados
1.512 Vistas
Hello Spacekiek,
Were you able to set HDMI Scaling in RX Vega M Settings?
I will be glad to assist if you need any further help.
Wanner G.
Responder
