22671 Diskussionen
Intel Iris Plus on Microsoft Surface Pro 7 (i7) : Sidefx Houdini UI not working
Miche_79
Einsteiger
5.807Aufrufe
there seems to be an issue with the drivers 25.x and higher on the Microsoft Surface pro 7 (i7) Intel Iris Plus and Sidefx's Houdini (any version).
The interface looks teared apart and empty, while opengl view can be navigated, either way it is unusable.houdiniIrisPro_broken.jpg
Can the drivers be looked up and adjusted for this application since it is used to work on other Intel cards?
thanks in advance
10 Antworten
Alberto_R_Intel
Mitarbeiter
5.279Aufrufe
Miche_79, Thank you for posting in the Intel® Communities Support.
We recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them work with your specific platform.
In the following link you will find the drivers that are validated by Microsoft as the proper ones for your system, please test those drivers:
https://www.microsoft.com/en-us/download/details.aspx?id=100419
If the problem persists after that, please provide the model of the Intel® Processor installed on the computer and the Windows* version that you are using. I checked the specifications of it and it actually supports 3 different types of Intel® Processors, so we want to confirm those details:
https://www.microsoft.com/en-us/p/surface-pro-7/8n17j0m5zzqs?activetab=techspecs
Alberto R.
A Contingent Worker at Intel
Miche_79
Einsteiger
5.279Aufrufe
Hello Alberto, I do already have the latest available display drivers from Microsoft that are coming installed with the Surface Pro, there were no further updates according to their updates history​ on the page you provided. So, yes the problem persists. ​ The cpu of the Surface pro 7 i7 is: Quad-core 10th Gen Intel® Core™ i7-1065G7. ​ Thanks
Alberto_R_Intel
Mitarbeiter
5.279Aufrufe
Hello Miche_79, Thank you very much for providing that information.
Just to let you know, when using a Surface Pro 7, it is recommended to install the driver package provide by Microsoft, since you already did that and the problem remains and based on the fact that the Intel® Core™ i7-1065G7 Processor works with Intel® Iris® Plus Graphics, we can also try to install the Intel® Generic Graphics driver version 26.20.100.7463:
https://downloadcenter.intel.com/download/29195/Intel-Graphics-Windows-10-DCH-Drivers
In some cases, the Surface Pro 7 will not recognize the Intel® Generic driver as compatible, in that situation the best thing to do then will be to get in contact directly with Microsoft for further assistance on this matter:
https://support.microsoft.com/en-us
Alberto R.
Miche_79
Einsteiger
5.279Aufrufe
Hello Alberto, I did already try to update the drivers manually using the 26.xx zip files but the UI problem was still present. I'll check again with the very latest version suggested and get back to you. Thanks
Alberto_R_Intel
Mitarbeiter
5.279Aufrufe
Hello Miche_79, Thank you very much for sharing those details.
Perfect, no problem at all, take your time to test the driver and once you get the chance please let us know the results.
Alberto R.
Miche_79
Einsteiger
5.279Aufrufe
Hello Alberto,
I've managed to install the 26.20.100.7463 on the surface pro 7 however the issue persist.
Is it something that can be looked at for the next drivers iteration?
Alberto_R_Intel
Mitarbeiter
5.279Aufrufe
Hello Miche_79, Thank you very much for letting us know those results.
In this case, at this point, the next thing to do will be to get in contact directly with Microsoft to confirm which are the proper drivers for your system and for them to provide further technical assistance on this matter.
Alberto R.
Miche_79
Einsteiger
5.279Aufrufe
Alberto, this is a graphic driver provided by Intel to Microsoft: even if Microsoft certifies your latest drivers and includes them in their updates it won't resolve the issue reported since as i mentioned they still do not make the software usable. So, shouldn't be Intel supposed to provide support to the matter?
Miche_79
Einsteiger
5.279Aufrufe
Hello again, I'm writing back to report that the newest drivers from Dec 18th are finally fixing the problem encountered. Thanks for the support!
AdrianM_Intel
Mitarbeiter
5.278Aufrufe
Hello Miche_79,
Thank you for the update.
We are glad to know that everything is working fine now.
Hopefully, this will help other peers.
Adrian M.
Antworten
