23259 Discussions
Intel Iris Xe Aspect Ratio
OUS
Intel Iris Xe does not support a 21:9 aspect ratio. Is there going to be a fix? The display works fine with two other computers, both of which have NVIDIA graphics and automatically detect the correct aspect ratio and resolution (UWQHD). All computers have the same version of Windows 11, and I've tried both the Windows generic drivers and the display manufacturer's drivers. I've also tried changing settings in Windows and the Intel Graphics Command Center. Different refresh rates do not have any effect.
MUC
Honored Contributor I
Unfortunately, the problem lies with the hardware of the ASUS VivoBook 15 (F515EA). Although the Intel Core i7-1165G7 with integrated Iris Xe Graphics features an HDMI 2.0 interface, ASUS has decided to only offer HDMI 1.4 on the external graphics port when implementing it in this laptop in the lower price segment.
You must use the ASUS F515EA graphics driver V31.0.101.4255 (2023/04/13).
If that doesn't help, you should contact ASUS Support. However, you may have to do without UWQHD with the HDMI port offered here by ASUS.
