23588 Discussions
Intel Iris Xe Graphics Causing Stutters/Freezes in Command & Conquer Generals Multiplayer
Gazername
Hello intel teams
I am experiencing performance issues with my IGPU while playing C&C generals and its Zero Hour expansion in multiplayer, I encounter stutters and freezes during gameplay, even my intel drivers are already updated to the latest version. I even set low graphics settings and installed a community patch called GenPatcher but the issue still persists
My laptop Specs:
CPU: intel core i913900H with Intel Iris Xe
RAM: 16GB
OS: Windows 11 25h2
According to the C&C Community, the problem may be related to intel iris xe or Intel UHD integrated graphics stability, as similar issues do not occur on dedicated GPUs I would like to know if there are any known fixes, patches, or settings adjustments to improve intel iris xe stability for older games like this.
KentRusselP_Intel
Hi Gazername,
Thank you for reporting this issue. Our priority is to target the most popular games and apps to focus our efforts on providing a high quality, stable experience for the broadest set of users. We will continue to improve our software performance and compatibility throughout this year and beyond. While we can’t accommodate your request at this time, please watch this article on our website for any possible changes to this situation.
Kent Russel P.
KentRusselP_Intel
Hi Gazername,
Thank you for reaching out to the Intel Community Forum. Please disregard the previous post, and I sincerely apologize for any confusion or inconvenience it may have caused. I appreciate your message, and I want to assure you that I’m here to assist you with your concern. To help us better understand the issue and provide accurate troubleshooting, could you please share the following details:
Gameplay Behavior
  • Do the stutters or freezes occur only in multiplayer modes, or do you also experience them in single‑player campaigns?
  • How often do these stutters/freezes happen (e.g., every few minutes, completely random, or triggered by specific actions)?
  • When the game freezes, does it recover on its own after a few seconds, or do you need to restart the game entirely?
  • During multiplayer matches, at what stage do the issues typically appear—game startup, mid‑game, or during large-scale battles?
Compatibility & Modifications
  • Have you tried running the game in compatibility mode for older Windows versions?
  • Did you test the game before installing GenPatcher to confirm whether the issue occurred with the unmodified (vanilla) version?
Performance Monitoring
  • Have you monitored GPU usage, temperatures, and memory usage during gameplay?
  • Have you tried applying different graphics configurations through the Intel® Graphics Command Center?
  • Have you tested other older games—particularly RTS titles—to see if the same behavior occurs?
  • Do you notice any graphical issues in modern games or applications?
Driver & System Testing
  • Have you used Display Driver Uninstaller (DDU) before installing or updating to the latest Intel graphics driver?
In addition, to help us better understand your system configuration and provide the most accurate assistance, we kindly ask that you share the Intel® System Support Utility (SSU) report from your device. This report contains essential information about your hardware and software setup that will help us pinpoint potential causes.
  1. Download and run the Intel® SSU tool.
  2. Allow the tool to scan your system and generate the report.
  3. For step‑by‑step instructions, refer to this guide: Help Guide for the Intel® System Support Utility
  4. Once the scan is complete, please attach the generated text file to your reply.
If you have any additional questions or need further assistance, please don’t hesitate to let us know. We’re here to help.
Kent Russel P.
KentRusselP_Intel
Hi Gazername,
I just wanted to follow up and check if you’ve had a chance to review the information I shared previously. Your feedback is important, and I’d appreciate it if you could share your thoughts at your earliest convenience.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
Gazername
Hello Intel support Team,
Thank you for your response.
My laptop is not overheating temperatures remain normal while playing.
The stuttering and freezing occurs mainly during multiplayer gameplay. singleplayer
is more stable, but multiplayer becomes unplayable due to frequent freezes.
the stutters become much worse in large battle situations like over 30 minutes of gameplay.
Compatibility setting i have already tried running the game in Windows compatibility mode
and enabled Run as Administrator, but the issue still persists. I also performed a clean reinstall of the
Intel Graphics driver but did not resolve the problem.
Based on feedback from C&C community, this appears a known issue affecting many laptop users with intel
integrated GPUs like mine, they say the problem is related to poor support or instability with DirectX8/ legacy
rendering newer intel driver.
Many players report that the only workaround is forcing the game to run on a dedicated GPU that completely fixes the problem, but my system does not have a dedicated GPU so i cannot use that solution.
Please let me know if intel is aware of any driver-level compatibility, performance and optimizations
for older games like C&C Generals and Zero Hour expansion.
KentRusselP_Intel
Hi Gazername,
Thank you for your response. Could you please share the Intel® System Support Utility (SSU) report from your device? This report provides critical details about your hardware and software configuration, which will assist us in identifying possible causes of the issue.
To do this:
Additionally, to help us investigate further, please answer these questions:
  • When the game freezes, does it resume automatically after a few seconds, or do you have to restart it completely?
  • Did you try running the game before installing GenPatcher to check if the problem existed in the original (vanilla) version?
  • Where did you download your Graphics drivers from? Was it the Intel website or your laptop manufacturer’s site? Please note that Intel provides generic drivers only.
  • What platform are you using for the game? is it steam?
If you have any other questions or need more help, feel free to reach out. We’re here to support you.
Kent Russel P.
Gazername
Hello kent,
Thank you for your reply.
Answers:
1. When the issue occurs during multiplayer, the game does not fully crash. Instead, it experiences heavy stuttering, and the screen begins to flicker while the match continues running. the audio remains normal, and gameplay sometimes resumes after few seconds, but the frequent stutters and freezing makes gameplay unplayable, especially during large intense battles.
2. Yes, I already experienced the same stuttering/freezing issue even before installing GenPatcher. GenPatcher did not resolve the problem.
3. I downloaded and installed my intel graphics driver from the official Intel website using the Intel Driver & Support Assistant.
4. Yes, I am using the steam version of C&C Generals Zero Hour.
 I have provided the intel SSU report as requested.
KentRusselP_Intel
Hi Gazername,
Thank you for your response. Please try to use Display Driver Uninstaller (DDU) to completely remove the current graphics driver and proceed to install the recommended OEM graphics driver for your device from this link: https://www.asus.com/laptops/for-home/vivobook/vivobook-16-oled-x1605/helpdesk_download?model2Name=X1605VA
Here is a link for your reference on how to do a complete clean installation of graphics driver using Display Driver Uninstaller (DDU): https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
Kent Russel P.
KentRusselP_Intel
Hi Gazername,
Kent Russel P.
KentRusselP_Intel
Hi Gazername,
As I haven’t received a response, I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
