23767 Discussions
Intel Iris Xe Graphics driver
Tan0002
Dear Intel Support Team,
We 've a problem with the Intel core i7-1180g7 processor.
We can't find the driver for it on the Intel product, so we use the  Intel Graphics- Windows* DCH Drivers. When we start the PC, after running bios to login, it shows black screen. if we uninstall the driver, the pc run normally. So:
- How  do we fix the black screen ?
- which driver and version should we install?
- When will there be a driver for this processor?
ps: we are OEM, we use the processor for our product. It use windows 10 20H2, window 10 21H1.
I have checked all connectors, they are working fine.
Thank you
Best Regards!
Alberto_R_Intel
Tan0002, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance and provide the answer to your questions, first, we just wanted to confirm a few details about your system:
What is the model of the laptop?
Is this a new computer?
Was it working fine before without the black screen issue?
Did you make any recent hardware/software changes besides installing the graphics driver that might cause this problem?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Tan0002
Dear Albert R.
We are building a new product for the company, It uses the intel core i7-1180g7 so we want a driver for graphics on this processor. We believe that the Intel Graphics driver- Windows * DCH Drivers are not compatible with the processor.
I answer your questions as follows:
It uses the processor intel core i7-1180G7 with graphics intel Iris Xe graphics
Yes
Yes, it was.
yes, we have a little hardware change but we don't think it will affect the graphics
The problem happens in the work environment.
I have a question: why is there still no driver for the processor ? When will that driver be available ?
Thank you,
Best Regards.
Tan.
Alberto_R_Intel
Tan0002, Thank you very much for providing that information.
In this case, it is important to mention that the Intel® graphics drivers are generic, meaning they might or might not work with your machine since it does not contain the customizations done by the OEM.
Based on that, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with that specific platform.
You mentioned that you already tried an Intel® DCH graphics driver, just to confirm, was it 30.0.101.1660? If you haven't tested that driver version, please try a clean installation of that driver following the instructions in the links below and once you get the chance, let us know the results.
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html?wapkw=intel%20iris%20xe%20graphics
Albert R.
Alberto_R_Intel
Hello Tan0002, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello Tan0002, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Still, in this case, to install the graphics driver provided by the manufacturer of the computer will be the best thing to do, since that driver contains the proper customizations for the optimal functionality of your computer.
Albert R.
nargesst
hello
I have same problem as tan0002
it looks like my laptop is blinking
it  is asus X515 core i7 11G and intel iris xe
the black screen issue happens to me a lot and i just bought my laptop 1 month ago and its bothering me
do you know how can i fix this ?
thanks for your time .
