22672 Diskussionen
Intel Iris Xe Graphics (i5-1135G7) — LiveKernelEvent 141, artifacts, screen flickering,
Ciaramid06
Einsteiger
3.797Aufrufe
I’m looking for a solution to a very annoying and persistent issue affecting many laptops with Intel i5-1135G7 CPUs and integrated Iris Xe graphics (Gen12 LP).
The issue:
  • Random crashes during GPU-heavy applications (Nintendo Switch emulator Suyu, 3D software, games, or even browsers with hardware acceleration enabled).
  • Graphical artifacts: lines, distortions — especially around loading icons like YouTube's spinning wheel.
  • LiveKernelEvent 141 reported in Windows reliability monitor (igdkmdn64.sys involved).
  • After the crash, the display starts flickering until I restart the system.
What I’ve already done:
Memory fully tested with MemTest86 — no errors.
Tried both OEM drivers from Asus and latest Intel DCH drivers — same issue on all versions.
Switched between Vulkan, OpenGL, Direct3D11 in multiple applications — the problem persists (only OpenGL is slightly more stable).
Disabled hardware acceleration in Opera GX — the issue disappears.
Tested with Google Chrome — works fine, no artifacts.
14 Antworten
Earl_Intel
3.715Aufrufe
Hi Ciaramid06,
I appreciate you sharing and gathering your findings regarding to the random crashes on your system.
To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • Since you stated you're using Nintendo Switch emulator Suyu, may I know if you're a developer or and end user?
  • Do you have a specific game or application that's experiencing these crashes?
  • What is the exact make and model of your laptop?
  • Since you stated that even using the OEM drivers, the issue still persists, have you already contacting your OEM about the issue?
Earl E.
Ciaramid06
Einsteiger
3.697Aufrufe
Thank you for your reply.
I am an end user, not a developer.
The crash happens with multiple applications, but I initially noticed it using the Nintendo Switch emulator Suyu — although the issue also appeared with other GPU-intensive software and even during web browsing when hardware acceleration was enabled (for example, in Opera GX browser).
My laptop model is:
ASUS F515EA / X515EA
equipped with an Intel i5-1135G7 CPU and integrated Intel Iris Xe Graphics.
Yes, I have already contacted my OEM (ASUS Support) in the past, and their only suggested solution was reinstalling their OEM version of the Intel driver. Unfortunately, the problem persists even with both OEM drivers and Intel generic drivers.
The system consistently reports:
  • LiveKernelEvent 141 (igdkmdn64.sys)
  • Followed by screen flickering until restart.
I’ve already tested:
  • Memory (MemTest86) — no errors.
  • Different driver versions, including both OEM-provided and Intel DCH drivers.
  • Disabling hardware acceleration in some apps prevents the crashes, but this is not a real solution.
I saw it seems to be a common problem among other users who own laptops with the same Intel i5-1135G7 CPU + Intel Iris Xe Graphics GPU, from different brands (ASUS, HP, Dell, Lenovo) at least I saw in different forums that they had the same problem as me (like screen flicker or artifacts or lines) after heavy loads like games or other applications
I hope this extra information can help to investigate further or escalate the case.
Thanks again for your support!
Earl_Intel
3.651Aufrufe
Hi Ciaramid06,
Thank you for sharing this additional information with us.
I'll take note on this and will further investigate the cause of the issue internally.
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Ciaramid06
Einsteiger
3.633Aufrufe
hi I scanned with the utility you sent me, now I attach the txt file, I hope it is useful to find a solution.
Earl_Intel
3.603Aufrufe
Hello Ciaramid06,
I appreciate you sharing the SSU logs.
I have a few more additional questions for me to further isolate the issue.
  • Have you attempted to access your laptop's BIOS? Does the BIOS also have the flickering problem?
  • Have you attempted to use an external monitor to see if the flickering problem still exists there?
Earl E.
Ciaramid06
Einsteiger
3.586Aufrufe
no in the bios I have not seen flickering or anything but it happens on windows especially with heavier activities and unfortunately it is random and apparently it has not happened with a second monitor but I should do other checks to confirm it because sometimes the crash occurs and then the flickering, while on opera GX the images have lines or artifacts for a while then on youtube videos the wheel and the hud of the 10 seconds forward and back go to make a frame of white lines. I uploaded the image of a video on youtube in full screen if you can see the lines it creates, this one on opera gx only does it with hardware acceleration active in which the browser uses the GPU
RandyT_Intel
3.409Aufrufe
Hi @Ciaramid06 ,
Upon checking, it appears that your BIOS is outdated. Please try updating the BIOS to its latest version. You may contact your system manufacturer for additional assistance, and you can find the updated version here ASUS X515 (11th Gen Intel)|Laptops For Home|ASUS Global. Additionally, if the issue occurs only within the operating system and not in the BIOS or on any external display, it could be a potential driver compatibility or conflict issue with the operating system. In the worst-case scenario, it might be a hardware issue with the main display.
Please let me know if there are any changes once you have updated the BIOS.
Randy T.
Ciaramid06
Einsteiger
3.371Aufrufe
I already have the updated bios, the latest version is 316, unfortunately this is the most recent.
RandyT_Intel
3.342Aufrufe
Hi @Ciaramid06,
The error message "LiveKernelEvent 141" associated with "igdkmdn64.sys" typically signifies an issue with the Intel Graphics Driver on a Windows system. While you may have already attempted various troubleshooting steps, simply updating or using OEM and Intel generic drivers might not suffice without executing a clean installation. Could you clarify how you performed the reinstallation of these drivers? I recommend using Display Driver Uninstaller (DDU) to completely remove residual old drivers, as it ensures a thorough cleanup.
Additionally, corrupted system files can contribute to various errors, including this one. Utilize the System File Checker tool to scan and repair these files. To do this, open Command Prompt as an administrator and execute the command
sfc /scannow
Since disabling hardware acceleration is not an option for you to resolve this. Check for overheating or hardware malfunctions, it can also trigger this error. Verify that your system is not overheating and that all hardware components are functioning correctly. If these steps do not resolve the issue, consider seeking further assistance from the OEM or a professional technician, as there may be deeper system or hardware issues involved. Since the issue is not apparent in BIOS or on an external monitor, you may also consider performing an OS reinstallation (OSRI) to test if flickering persists sometimes Windows updates can cause compatibility issues with drivers. Please ensure you back up your data before proceeding with this step.
Randy T.
RandyT_Intel
3.221Aufrufe
Hi @Ciaramid06,
Randy T.
Ciaramid06
Einsteiger
3.170Aufrufe
I scanned with sfc /scannow and it didn't detect any problems before I uninstalled the video drivers with DDU, now let's see in a few days if it still gives me problems
Earl_Intel
3.012Aufrufe
Hello Ciaramid06,
Thanks for your response.
Sure thing! Give us an update once you already monitored the performance of your system.
Tell us if the problem will still exist or if it has been resolved.
Earl E.
Earl_Intel
2.879Aufrufe
Hello Ciaramid06,
I was wondering whether you have already observed your system and if the same problems persist.
Let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
Earl_Intel
2.811Aufrufe
Hi Ciaramid06,
Earl E.
Antworten
