22671 ディスカッション
Intel Q45/ Q43 Display adapter: Is this ...?
RLafa1
ビギナー
6,338件の閲覧回数
Running WIN8.1, Pro; other specs of the computer: Intel Quad core 2, Quad CPU, Q9550 @2.83Ghz, 8gb ram, 64 bit.
I have a new Dell U2415 displayport monitor with 1.2 capability. I wish to daisy chain from the Dell to an Acer G226HQL monitor.
Is the graphics adapter certified to allow for this daisy chain setup? That is, Can graphics adapter support DPMST/ HBR2 (High Bit rate)
I can not seem to get a picture on the Acer, daisy chaining to the Dell and wonder if it is something I may have done incorrectly.
Can the issue be the ACER?
Please advise.
0 件の賞賛
16 返答(返信)
Kevin_M_Intel
従業員
4,501件の閲覧回数
Hello RJL24,
I am going to verify this information and I will be back as soon as possible.
Kevin m
RLafa1
ビギナー
4,501件の閲覧回数
Thank you. Looking forward to reading the results of your research.
Kevin_M_Intel
従業員
4,501件の閲覧回数
Hello RJL24,
Kevin m
RLafa1
ビギナー
4,501件の閲覧回数
ROBERT_U_Intel
従業員
4,501件の閲覧回数
@RJL24, the Q9550 CPU does not have integrated graphics. Are you certain that is the processor in your system? Could you please attach the DXDiag report to this thread.
Robert
RLafa1
ビギナー
4,501件の閲覧回数
"Intel Quad core 2, Quad CPU, Q9550 @2.83Ghz, 8gb ram, 64 bit."
I suspect this system does not support my Daisy chain needs.
Here is the DX diagnostic info on this system..
Thank you for your help.
Please advise..
RJL24
Kevin_M_Intel
従業員
4,500件の閲覧回数
Hello RJL24,
Thank you for sharing this information. Based on the report you provided, this processor does not have onboard graphics so the configuration you are attempting will depend on the motherboard limitations o capabilities.
My recommendation at this point is to confirm with the motherboard manufacturer if it can support DPMST/ HBR2.
RLafa1
ビギナー
4,500件の閲覧回数
Thank you.
How do I find out about the motherboard and its manufacturer?
How do I confirm?
Cordially,
RJL
ROBERT_U_Intel
従業員
4,500件の閲覧回数
@ RJL24,
Your system is made by HP, the driver downloads for the system is here: http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=4065873&swLangOid=8&swEnvOid=4060 http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=4065873&swLangOid=8&swEnvOid=4060
However, HP does not list Windows 8.1 as a supported OS for your system. Additionally, HP list 5 possible graphics options for your system as follows:
That said, if your system did have the Intel Q43/Q45 graphics, it would not support daisy chaining of displays or have updated Intel graphics driver avail for it. Intel did not provide graphics drivers for the Q43 /Q45 graphics on Windows 8/8.1. Inbox drivers provided by Microsoft are the only available drivers for this combination.
Robert
RLafa1
ビギナー
4,501件の閲覧回数
Thanks for a great explanation.
I'm not going to worry about Daisy chaining this configuration. Too complicated.
It works fine with 2 monitors normally connected: one via USB to HDMI, and the other via dvi to dvi.
Graphics are excellent this way.
Than you again.
ROBERT_U_Intel
従業員
4,501件の閲覧回数
Robert
RLafa1
ビギナー
4,501件の閲覧回数
Please advise..
RJL24
Kevin_M_Intel
従業員
4,501件の閲覧回数
Hello RJL24,
RLafa1
ビギナー
4,501件の閲覧回数
Thank you.
How do I confirm?
Cordially,
RJL
ROBERT_U_Intel
従業員
4,501件の閲覧回数
@ RJL24,
Robert
RLafa1
ビギナー
4,501件の閲覧回数
Than you again.
返信
