23784 Discussions
Intel(R) HD Graphics 3000 - HDMI is not detected!!
KHofm1
As this topic seems to be forgotten, I bring it up here once again.
Many people are waiting for a solution to this known malfunction since many months!
Here are my reports:
Report Date: 5/14/2013
Report Time[hh:mm:ss]: 18:52:13
Driver Version: 8.15.10.2752
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Swedish (Sweden)
DirectX* Version: 11.0
Physical Memory: 3979 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 242 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2294 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2137.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13,39 inches
Vertical: 07,48 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 0D AF 90 15 00 00 00 00
1F 13 01 03 80 22 13 78 0A D1 F5 93 5D 59 90 26
1D 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 60 1D 56 BC 50 00 26 30 1E 3F
4C 00 58 C2 10 00 00 18 00 00 00 FE 00 4E 31 35
36 42 36 2D 4C 30 44 0A 20 20 00 00 00 FE 00 43
4D 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 4E 31 35 36 42 36 2D 4C 30 44 0A 20 20 00 4D
* Other names and brands are the property of their respective owners. *
System Information
Time of this report: 5/14/2013, 19:03:53
Machine name: KLAUS-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: Swedish (Regional Setting: Swedish)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: X501A
BIOS: BIOS Date: 05/02/12 10:23:32 Ver: 04.06.05
Processor: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3980MB RAM
Page File: 2628MB used, 5329MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: None
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_14F71043&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Model: unknown
Monitor Id: CMO1590
Native Mode: 1366 x 768(p) (60.039Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2752 (English)
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 5/22/2012 09:47:36, 8089088 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-3379-FD34A9C2C535}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x14F71043
Revision ID: 0x0009
Driver Strong Name: oem9.inf:IntelGfx.NTamd64.6.0:iSNBM0:8.15.10.2752:pci\ven_8086&dev_0116&subsys_14f71043
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87F...
KHofm1
"The computer does not fullfill the miminum requirements to install these updates"
It says something along those lines
Marcos_U_Intel
You can either force to install our generic driver via the Have Disk/Known File method at the link below:
http://www.intel.com/support/graphics/sb/CS-022355.htm http://www.intel.com/support/graphics/sb/CS-022355.htm
or install the original driver provided by your system manufacturer from the following URL:
http://www.intel.com/support/oems.htm http://www.intel.com/support/oems.htm
