23807 Discussions
Intel RST Update Fails
bencefiu
I have tried several times, and at the end, the update fails. Full name of update:
Intel® Rapid Storage Technology (Intel® RST) User Interface and Driver for Intel® 5th/6th Generation Platforms
My laptop: HP EliteBook 840
Log attached. Let me know if you can help me!
DeividA_Intel
Hello bencefiu,
1. Are you using the Intel® Driver & Support Assistant to perform the update?
2. Have you tried to manually install the driver?
3. Have you tried with the driver version from HP?
4. If you have a 5th/6th gen CPU, try the following driver version 14.8.16.1063 since it will be compatible with your hardware:
- https://downloadcenter.intel.com/download/26759/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver
Deivid A.
bencefiu
Thank you for responding Deivid
1. Yes, Im using  Intel® Driver & Support Assistant
2. Yes, After going on for a while, the update failed, at around the end.
3.  I don't think so, I can't really figure out what that is right now.
4. Tried it, the same thing happened, installation failed.
DeividA_Intel
Hello bencefiu,
Thanks for the information provided.
In order to help you further, please try the following:
1. Make sure that you are a supported browser (Chrome, Firefox, or Edge) to run the Intel® Driver & Support Assistant (Intel® DSA).
2. Uninstall and reinstall the Intel® Driver & Support Assistant (Intel® DSA):
- Uninstaller: https://downloadcenter.intel.com/download/30496?v=t
- Tool: https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant
3. Check the driver version from Intel® Rapid Storage Technology (Intel® RST) (Intel® Driver & Support Assistant) and the version already installed. If it is the same there is no need to install it.
4. Uninstall and reinstall the Intel® Rapid Storage Technology (Intel® RST):
- Driver (15.9.8.105): https://downloadcenter.intel.com/download/28997/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver
Also, I would like to let you know that if you are not using the Intel® Rapid Storage Technology (Intel® RST), you can uninstall it since is not needed by your system.
Deivid A.
DeividA_Intel
Hello bencefiu,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello bencefiu,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
