22649 Discussions
Intel UHD 620 : how to set detailed global 3D settings
PVrel
Hello
I need to turn off "Multi-sample Anti-Aliasing" for all my Applications (without having to add the applications one by one)
Is it possible?
Thank you in advance
Stefan3D
There should be an option in the 3D tab of the control panel.
Doesn't it appear on your rig?
PVrel
Thank you so much for your quick reply Stefan3D.
No, in my rig, I have only the upper option available... This is weird!
May I ask which driver version are you using?
(I am using the latest)
Thank you again.
Stefan3D
I'm using driver 20.19.15.4835 on Broadwell HD 5500.
Don't know if this a matter of driver branch or GPU generation
PVrel
Thank you again Stefan3d!
I am using a Acer Spin 5 laptop.
After a small research, I found out that I cannot use native inter drivers; my win10 system accepts only custom intel drivers from Acer...
I guess that this is the problem.
I don't know if there is a way to solve this...
Stefan3D
Actually i have an Acer laptop as well.
You mean the validation error.
Get drivers from this list https://downloadcenter.intel.com/product/126789/Intel-UHD-Graphics-620 Downloads for Intel® UHD Graphics 620
Install driver via "have disk method" as described at:
www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
PVrel
Thank you so much for your efforts to help me Stefan.
I have followed your instructions and installed the intel drivers, but unfortunately the problem still persists...
I can't think of anything else to try...
