23268 Discussions
Intel UHD 750 (i7 11700) graphics problems
Voloom
I have problems with displaying QR-code of web.whatsapp.com (screenshot is attached).
Display driver 27.20.100.9466.
Support Utility and graphics driver reports are also attached.
Display is connected via HDMI.
The problem does not depend on browser. I tried Chrome, Edge and IE.
Maxim
Alberto_Sykes
Hello Voloom and everybody, I just received an update on this matter.
Just to let you know, currently, we are investigating this under the bug ID: 14013495876 as you can confirm in the thread below, where we are posting all the updates about it. Also, our development team has confirmed this issue is no longer visible in our latest internal driver build that we expect to have soon available in the main thread:
https://community.intel.com/t5/Graphics/Iris-Xe-and-AWS-Workspaces/m-p/1281134/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtPTVdWNVZQVldaVTNUfDEyODExMzR8U1VCU0NSSVBUSU9OU3xoSw#M97020
Albert R.
Alberto_Sykes
Voloom, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new computer?
When did you purchase it?
Did you build it?
Was it working fine before?
Did you make any recent hardware/software changes?
Does the problem happen at home or in a work environment?
Albert R.
Voloom
Hello Albert,
Thanks for your reply.
1. This is a new computer.
2. I purchased it 31 March 2021.
3. Yes, I built it myself.
4. The problem with QR-code is from the first day. In the other cases computer works fine.
5. Hardware was not changed. Software - the last Windows update and last graphics driver.
6. Computer is used in home environment (plus remote work).
Maxim
Alberto_Sykes
Hello Voloom, You are very welcome, thank you very much for providing that information.
Based on the SSU report, we can confirm that the graphics driver version currently installed is 27.20.100.9466, which is the latest Intel® Generic Graphics driver we have available on our website:
https://downloadcenter.intel.com/download/30381/Intel-Graphics-Windows-10-DCH-Drivers
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked in Gigabyte's website and the latest Graphics driver they have available is version 27.20.100.9316, please try a clean installation of that driver following the instructions in the link below:
https://www.gigabyte.com/Motherboard/B560M-AORUS-PRO-AX-rev-10/support#support-dl-driver-vga
Also, please try any of the QR codes from the following site just to confirm if the problem is actually related to the Whatsapp application:
https://www.qr-code-generator.com/
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Albert R.
Voloom
Hello Albert,
I  have installed 27.20.100.9316 driver from Gigabyte site using your instruction for clean driver installion.
QR code at whatsapp site works correct with Microsoft base driver, but after installation of Intel driver becomes broken again.
But qr generated by qr-code-generated.com looks better.
Maxim
MertDalbudak
I am having the same issues.
I have an i7-11700
QR Codes are broken and I get some weird artefacts on Chrome as well.
Alberto_Sykes
MertDalbudak, Thank you for posting in the Intel® Communities Support.
Hello Voloom, Thank you very much for sharing those results.
We are sorry to hear the issue persists, we will do further research on this matter, as soon as I get any updates I will post all the detail on this thread.
Albert R.
Tunder96
Good evening. I have the same issues with an i7-11700.
Driver are updated (27.20.100.9466) and Intel Processor Diagnostic Tool does not report any problem.
The issue disappear only if the UHD 750 drivers are unistalled and PC works only with the Microsoft Basic Graphics Video driver.
Alberto_Sykes
Hello Voloom, I just received an update on this matter.
While we are currently still working on this case, we just wanted to confirm if hardware acceleration is enabled in Windows or Browsers?
If so, could you please try to disable that feature and test the QR codes and apps you are running and let us know the outcome?
Albert R.
MertDalbudak
Yes it fixes the issue when HW accel is off in chrome.
Voloom
Hello Albert,
Yes, without hardware acceleration works ok
Maxim
Alberto_Sykes
Hello Voloom, MertDalbudak, thank you very much for confirming that information.
We will continue with our research on this matter, I will post all the updates in this thread.
Albert R.
Alberto_Sykes
Albert R.
MertDalbudak
Hello Albert,
I just got an update via Windows Update (27.20.100.9127) today and the problem still persist.
Kind Regards
Mert
TECHFIND
Solved with Mozilla
Also solved with Latest version: 27.20.100.9616
TECHFIND
Solved with Mozilla
Voloom
Hello Albert,
Yes, it works with 27.20.100.9616
Thank you!
Alberto_R_Intel
Voloom, You are very welcome, thank you very much for providing those results.
Perfect, excellent, it is great to hear that the problem with the QR code got fixed after installing the Intel® Graphics driver version 27.20.100.9616, hopefully, it will work for all the peers viewing this thread as well.
Any other inquires, do not hesitate to contact us again.
Albert R.
MertDalbudak
When will the driver be available as a stable driver?
Alberto_R_Intel
MertDalbudak, Thank you very much for your response.
There is no official statement from Intel® informing a specific date of release.
Albert R.
