23526 Discussions
Intel UHD Graphics 630 - Keyboard shortcut for Screen rotation
dhong4
In the control panel of Intel UHD Grapics 630, there are no settings of keyboard shortcuts for screen rotations. There are only two shortcut settings for "Ratio Toggle(?)", "Open graphic control panel".
The graphic driver is the latest version. How can I rotate the screen by keyboard shortcuts?
Hello, daegeunhong. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
I would like to start by mentioning that in newer drivers versions of the Intel® HD Graphics, the shortcuts to rotate the screen were removed. On the other hand, you can manage this through Windows* by right-clicking on your desktop > Display settings > Orientation drop-down.
Antony S.
Hello, daegeunhong.
I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results.
Antony S.
dhong4
I knew how to rotate the screen by mouse clicking. Just wanted to be able to do it easily by keyboard shortcut as its former version had enabled it. Wish the newer version of the Intel graphics had the better usability or at least maintain the same functions.
Anyways, thank you for your comment.
