22813 Discussions
Intel UHD Graphics 630 many issues
MBorz
I built a new system together. Based on the new Intel Coffe Lake CPU Core i7 8700, with integrated Intel UHD Graphics 630. And the ASUS ROG STRIX Z370-H Gaming Mainboard with newest Bios Version.
Windows 10 Fall Creators Update is up to date. Also, the official Intel driver for the iGPU is installed (15.47.02.4815).
However, many Software is not working properly at all. Like Example Cyberlinks Power Director 15+16 versions (on the current patch stand).
The preview in the timeline hangs constantly, and the image flickers constantly, or momentarily the Display goes completly black for a few seconds, and the software is not operable. Timeline playback stops or programs hang.
Furthermore, creating a BD disc is not possible because an error code is constantly being output. There are different error codes, including "eC0030106".
Before this - with the iGPU Intel HD Graphics 530 - everything ran smoothly.
Cyberlinks PowerDVD 17 (up to date) playback don't look smooth anymore, too.
Other Software which use the iGPU in Hardware didn't run well anymore. It looks like the iGPU Rendering doesn't work anymore.
All my Video Rendering Software like TMPENC didn't run with the Hardware Encoding of the iGPU (Intel UHD Graphics 630) anymore.
I have reinstalled Windows completly new, but nothing changes.
Is there anything changes in the driver ?!
When I use the Nvidia GTX1060 graphics card, there are no such problems at all.
I did not have any problems with all iGPU's before that, which is currently with the Intel UHD 630. The system runs very stable otherwise, even a test with Prime 95 did not cause any problems. Only when the iGPU becomes active, nothing works properly, as it should.
MBorz
Thank you very much for help.
Now i switch to antother Software Player, and all is great. With 1050 Interlaced Videos, too.
All is good now.
Merry Christmas and a happy new Year from Germany !!
Janami25: You are very welcome. Perfect, thank you very much for letting us know that information, it is great to hear that the problem got fixed and now everything is working properly.
Any other inquiry, do not hesitate in contact us again.
Merry Christmas and happy new year to you too.
Alberto R
AThab1
You must use specific cable
You must look at the specifications of your graphic card i have the same problem with UHD 630 and when I used hdmi 1.4 cable the problem solved
MDool3
I have an msi gl63 8sd seems the latest intel driver uhd 630 may be an issue pc dims quite a bit for 40 seconds when windows has loaded.
