Объявления
22767 Обсуждение
Intel UHD Graphics 630
radiolog
Начинающий
5 486Просмотр.
HDMI port is working,  displayport is not working.  Does this has to do with a driver update?  See my information
0 баллов
5 Ответы
DeividA_Intel
Сотрудник
5 450Просмотр.
Hello radiolog,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Is the issue recent? If not, when did it start?
3. Have you tried with different Display port cables?
4. Did you use adapters?
5. Have you tried with different TV/monitors?
6. Have you updated the operating system, including optional updates?
7. Have you updated your drivers?
Deivid A.
radiolog
Начинающий
5 432Просмотр.
I saved one with detailed view computer and another with display info.
2. The issue started last Tuesday  Jun 22
3. Yes
4.  No adapters
5.  I moved cable to another monitor - no change
6. Yes
7. Yes
DeividA_Intel
Сотрудник
5 396Просмотр.
Hello radiolog,
Thanks for the information provided.
Based on your report, please try the following:
1. Run Windows updates, including optional updates.
2. Update your Intel graphics:
- Driver: https://downloadcenter.intel.com/download/30381/Intel-Graphics-Windows-10-DCH-Drivers?v=t
3. Check with DELL for Display port firmware.
4. Check at the BIOS if the Display port outputs are disabled.
5. Check with DELL if there is a BIOS update available.
Deivid A.
DeividA_Intel
Сотрудник
5 383Просмотр.
Hello radiolog,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Сотрудник
5 357Просмотр.
Hello radiolog,
This issue seems to be related to hardware, if the issue persisted with both drivers and after the firmware update, I do recommend you to get in contact with Dell for a hardware inspection.
Also, since we have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
Ответить
