The display goes black when playing a video; the image returns when scrolling away from the video.
A strange horizontal warping effect also appears when moving the mouse.
The effect eventually disappears on its own. The glitch isn't visible *in* captured videos on the system itself. A black screen during video playback effectively rules out the monitor as the source of the problem.
Someone else is experiencing the same issue (10th generation Intel HD graphics):
July 20, 2026: The bug occurs regardless of the browser - whether Chrome or Firefox.
It makes no difference whether the driver is new (32.0.101.7088) or old (31.0.101.5592). The old driver had been installed for years, so it’s unlikely to be the cause.
Removed the driver using DDU and reinstalled it after restarting Windows. The Intel Graphics Command Center also reinstalled itself.
July 25, 2026: The error recurred before 10 PM. Right-clicking inside the YouTube video (opening the on-screen menu) fixes the black screen, but the warping persists. The warping disappears after minimizing the browser for 1-2 minutes.
Videos:
The Intel Processor Diagnostic Tool ran without a problem.
--- IPDT64 - Revision: 4.1.9.41
--- IPDT64 - Start Time: 29/07/2026 17:24:08
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Pass.
CPU 1 - GPUStressW - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPUFreq - Pass.
IPDT64 Passed
--- IPDT64 - End Time: 29/07/2026 17:28:14
PASSI suspect an issue with the video decoder as the problem always appears when playing a video. I also suspect a hardware issue as I cannot capture the warp effect on video directly on the system. Maybe an update in the software codec unveiled an issue in the hardware video decoder? YouTube mainly uses the vp09 codec.
I noticed the issue only appears after several hours of watching YT videos, that's why it mostly happens on the weekend. 😄
It really must be an issue with the video decoder, either in the driver or in the hardware.
It's hard to capture the effect on video so I made another one closer to the screen.
I got the bug again now after about 2 weeks without it. I watched YT videos for about an hour before the glitches and the black screen.
A reboot also fixes it. Here is the last video I watched when the bug appeared: https://www.youtube.com/watch?v=skqgEQrDpUA
But I don't think the issue is connected to specific videos. I hope somebody from Intel could answer here.
Sorry to hear you’re still running into this issue!
I took a look at the SSU report you shared, and it looks like your system is currently using an older graphics driver. As a first step, could you try updating to the latest graphics driver available and see if the issue still occurs?
Before installing the new driver, I’d also recommend doing a clean driver installation using DDU (Display Driver Uninstaller). This can help rule out any issues caused by leftover or corrupted driver files.
DDU Guide:
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Latest Graphics Driver:
Intel® 11th–14th Gen Processor Graphics – Windows*
Once you’ve completed the clean installation, let us know how it goes.
A few other details would also help us narrow this down:
1. Does the issue happen only on YouTube, or have you noticed it on other video streaming sites too?
2. Have you tried disabling hardware acceleration? If so, did that make any difference?
3. Is HDR enabled on your system?
4. How frequently does the issue occur, and roughly how long does it take before the black screen/warping effect appears?
5. Does this happen only while playing videos, or have you also noticed it during normal desktop use?
One other thing I want to mention for transparency: 11th–14th Gen Intel® Processor Graphics are now under Intel’s legacy software support model. This means future driver updates will mainly focus on critical fixes and security updates.
So, even if our developers are able to identify the root cause and develop a fix, there is a possibility that the fix may only be available for newer graphics platforms, such as Intel® Core™ Ultra processors, and may not be included in future drivers for your current graphics solution. For more details, you can check 11th Generation through 14th Generation Intel® Processor Graphics
That said, we’re still happy to take a closer look. If you’d like us to continue investigating, please share the results of the driver update/clean installation along with the answers to the questions above, and we’ll go from there.
Hi CM_Intel,
IIRC I also had the issue with the latest Intel driver. But I now installed it again. Another problem is the rollback of Windows to the old driver.
I followed this article now and did not do a clean install: https://www.intel.com/content/www/us/en/support/articles/000087834/graphics.html
Regarding your question:
1. I don't use any other streaming service so I can't really tell.
2. I think it's obvious that it's a decoder bug and disabling hardware acceleration would surely fix it but I'm not willing to do that.
3. No HDR active in Windows, just in the monitor itself, but I don't see how that would affect the GPU.
4. About once a week, more often on the weekend. It usually appears 1-8 hours after the PC is on.
5. This is exlusively when playing videos.
Thanks for the update. Please send the following so we can continue investigating:
1. Updated SSU Report
Generate a new Intel® System Support Utility report after reinstalling the graphics driver, and share it with us.
How to get the Intel SSU Logs on Windows
While generating the SSU report, kindly uncheck the “Networking” option.
2. Driver details
- Current graphics driver version installed
- Driver version Windows rolls back to
- Does the issue happen before or after the rollback?
- Any related entries in Event Viewer (Application/System logs) at the time it occurs?
We will review the provided information at the earliest opportunity and respond with next steps
I thought I was good with the new driver for a week now but the problem just came back in YT.
Sometimes it fixes itself when I restart the browser with Alt+F4and then right click in the YT video to see the context menu.
Same when the black screen bug is present, when I right click the YT video and show the context menu the black screen is gone, as soon as I click it away it is there again.
The driver did not roll back this time, so it doesn't seem to be related to a driver issue. Ambient temperature is 29.4 °C, GPU temperature is 49-56 °C.
I added the third-party log so you can see the errors, but they are not really connected to the GPU.
The last two entries in the system log one hour earlier are two Windows updates with "9PB1PFTHHM15-Microsoft.UI.Xaml.2.4" (updateGuid {806dcefb-ef9b-421f-816d-31c678fe7f5c}) and "9P105T65H4Z5-Microsoft.WindowsAppRuntime.1.3" (updateGuid {9cb29e39-f3f2-46f2-bd30-db571a7d5461}).
Thank you for the update and for sharing your observations.
Could you provide the following information:
- Have you tested the system with a different monitor? If yes, does the issue occur there as well?
- Could you check or replace the display cable and let us know if the behavior changes?
- Are you using any adapters, converters, docking stations, KVM switches, or extension cables between the graphics card and the display?
- If another compatible processor is available for testing, could you perform a swap test and check whether the issue persists?
- Provide the power supply (PSU) manufacturer and model, including the wattage rating.
- Have you tested the system with another graphics card? If so, does the issue occur with the alternate GPU?
Additionally, let us know:
- Monitor make and model.
- Connection type being used (HDMI, DisplayPort, etc.).
- Whether the issue occurs only in YouTube or if it has also been observed in other video playback applications or websites.
We look forward to your response.
- >> Unfortunately I don't have another monitor to test.
- >> Now using an HDMI cable on the same display.
- >> No.
- >> Not available.
- >> be quiet! System Power 9 CM 500W, 80 PLUS Bronze (BN301)
- >> Not available.
- >> iiyama G-Master G2740QSU-B1
- >> DisplayPort cable that came with the monitor, now HDMI.
- >> If the issue returns I will test platforms like Twitch or Odysee.
Thankyou for sharing the details.
Could you try testing with another streaming/video platform such as Twitch or Odysee and let us know if the issue occurs there as well? This will help us determine whether the behavior is specific to YouTube or affects video playback more generally.
Also, try the following:
- If you are using the YouTube app, uninstall and reinstall it.
- If you are using YouTube in a browser, clear the browser cache and test again.
- Temporarily disable Hardware Acceleration in your browser and use YouTube (or another streaming service) for an extended period.
- Monitor the system during playback and let us know if the issue reappears with Hardware Acceleration disabled.
Please share your observations once you've had a chance to test.
I now tested it with the HDMI cable for over a month without the issue, so there's something wrong with the DisplayPort connection.
I'll now switch back to the DP cable and if the issue appears again I'll reseat the cable on both sides to rule out an issue with the cable.
Hey, thanks for the update!
Great to hear HDMI has been solid for over a month with no issues. That points to the DisplayPort connection, cable, or something along that path as the culprit, rather than the graphics driver itself. For now, I'd stick with HDMI since it's working well for you.
Your plan to switch back to DisplayPort and reseat the cable on both ends if the issue comes back sounds like a good move. It should help figure out whether it's just a flaky cable or connection.
Also, Intel has put out a new graphics driver version, so it's worth updating to get the latest fixes. You can grab it here:
Intel® 11th – 14th Gen Processor Graphics - Windows*
If the issue pops up again, just let us know when it happens and anything you notice after reseating the cable.
Thanks again for sticking with this!
