22657 토론
Intel XE Max and Iris XE Frequent BSOD SYSTEM_SERVICE_EXCEPTION igdkmnd64.sys - ACER SWIFT 3X
Laksamanafadianzr
새로운 기여자 I
23,407 조회수
Hi, Intel I have numerous issue on my laptop and this is the worst beside the GPU that suddenly make any games crashed. I got BSOD every single day and it shows SYSTEM_SERVICE_EXCEPTION igdkmnd64.sys, I have installed many drivers, both OEM and from the Acer but no luck. This is insane considering this is a new laptop. I hope this DG1 XE and 11th gen are not a prototype product.
Additionally, When I plug in my external HDD with USB 3.0, the wifi will suddenly turned off and unable to detect any wifi around even the closest router. Please fix this ASAP because I begin loosing faith on the WIFI 6 certificiation.
0 포인트
25 응답
Stefan3D
명예로운 기여자 II
18,609 조회수
0 포인트
Laksamanafadianzr
새로운 기여자 I
18,598 조회수
It does not work. It still got the exact same blue screen in the first 30 minutes of using my Laptop. I will sue either acer or Intel for this.
0 포인트
chey
초급자
16,261 조회수
what about your laptop now? is the problem clear? or still the same? please drop any tips.
0 포인트
chey
초급자
16,257 조회수
i got the some problem here. how is your laptop now? is it normal? please give me the tips 😞
0 포인트
Reiyy
초보자
18,592 조회수
yeah, im having the same problem with my swift 3x. this is really frustating, it doesnt fixed even with the latest driver update. this product really feels like a prototype. i hope intel or acer will fix this problem, its really annoying that my laptop got BSOD every single day
0 포인트
Laksamanafadianzr
새로운 기여자 I
18,572 조회수
Please create similar threads every day so Intel will listen.
0 포인트
AlHill
수퍼 사용자
18,568 조회수
Bad advice.
What you need to do is to use ONLY the drivers provided by ACER.  If you still have the problem, contact ACER for support as they supposedly tested the drivers on their site with their hardware.
0 포인트
Laksamanafadianzr
새로운 기여자 I
18,565 조회수
Every manufacturer just customize the thermal design power. Besides, I have tried installing the Acer driver but no avail. Intel is they one that should be responsible in this case
0 포인트
AlHill
수퍼 사용자
18,557 조회수
"Intel is they one that should be responsible in this case "
Incorrect.  If you cannot install the ACER provided driver and/or it does not work, ACER is responsible for your support.
0 포인트
Laksamanafadianzr
새로운 기여자 I
18,552 조회수
Dude, really? just post a question thread regarding who should be responsible in this case and I'll give 1000 bucks if you can proof Acer is responsible. INtel is clearly the manufacturer here
0 포인트
AlHill
수퍼 사용자
18,544 조회수
Yes, Dud, really.
Acer designed and made your laptop.
Acer [supposedly] tested your laptop.
Acer provided you a warranty, that you paid for.
Acer likely modified the driver to work with their hardware.
Acer is responsible for your support.
You can, however, believe what you want.
I am no longer following this thread.
n_scott_pearson
수퍼 사용자
18,541 조회수
Al is correct.
Your warranty is from Acer. You have no (none, zero, nada) warranties of any kind from Intel.
Acer supposedly provided you with a set of drivers that will allow your laptop to run properly. If the system will not run properly with this set of drivers installed, well, then that is a problem that Acer needs to resolve.
Your statement "I will sue..." is a threat. This is a violation of the rules of conduct for this site. I suggest you improve your attitude right quick. Bully Talk is also against the rules of conduct, so I suggest that you think carefully before you respond.
0 포인트
chey
초급자
16,260 조회수
hi, i got the same problem with you. how is your laptop now? is it back to normal again? let me know the tips please
0 포인트
Maria_R_Intel
중재자
18,499 조회수
Hello Laksamanafadianzr,
Thank you for posting in the Intel* Community.
To better assist you we sent you a private message.
Maria R.
0 포인트
Laksamanafadianzr
새로운 기여자 I
18,491 조회수
Hi, Maria. I can't find any message. If you want to contact me, please do : Removing sensitive information. It's sad that Intel closed my previous thread about similar issue. Now, I am really frustrated and i want to sell this laptop.
0 포인트
AlHill
수퍼 사용자
18,486 조회수
You should check your private messages in the forum.
Remember, Every Single Second Matters...
0 포인트
Maria_R_Intel
중재자
18,474 조회수
Thank you for the information.
The proper team has now your details and they will contact you back soon by phone or email.
I removed your private information from your post.
Maria R.
0 포인트
limafoxtrot
초보자
18,261 조회수
Hi Maria,
Just reporting that the Feb XE/XE MAX drivers released this month do NOT resolve this issue.
I can stick with the stock ACER video drivers from August 2020, as has been reported in other threads, to prevent BSODs but (a) performance is clearly worse (FPS in games), (b) still crashing anyway (not BSOD).
Please see reports as requested to aid with your diagnosis and resolution of this.  This seems to be affecting another XE MAX laptop similarly (Dell Inspiron 7506) - see link in reports to (1) Acer Swift 3x 14'' i5-1135G7/8/512SSD Laptop: $798 C&C /+ Delivery @ Harvey Norman ($798 Delivered @ Amazon AU) - OzBargain.
I understand XE/XE MAX is relatively new and low volume, and the concept is great, but this is not a great start to Intel dGPUs.  I'd love to wave the flag for this product but it is currently impossible to do so.
I look forward to your response/next driver release.
Kind regards,
LF
0 포인트
limafoxtrot
초보자
18,251 조회수
I think I might've stumbled across something of a "solution" for people still experiencing crashing in-game with stock ACER video drivers.
For running games RIGHT NOW on the Swift 3X, DO NOT run an external display via USB C.
With USB C external display connected, the left hand deck was hot++, despite using cooling pad and XE MAX temps supposedly not getting above 60ish degrees.
Just now, on a whim, tried pulling out the USB connector, and (a) deck much less hot, and (b) no crashing out on limited testing so far (with stock ACER video drivers).
Perhaps running a high intensity task on XE MAX plus low intensity on XE (second display) just doesn't work out at this point in the driver evolution
0 포인트
EdS817
초급자
17,826 조회수
I am new to the Intel support community. I have a Dell Inspiron 7506 2n1 with the Intel IRISxe Max graphics and have gotten the BSOD 5-6 times over the first 5 weeks I have the computer. Dell has been less than helpful, they don't even acknowledge the problem. I did a Google search and found this so I'm hoping to find a fix here.
0 포인트
응답
