22672 Discusiones
Intel and AMD graphics adapters Inspiron 5537 and error 0x113
mabda2
Principiante
4.101 Vistas
my graphic cards are intel 4400 and amd 8850
when i use this fix bug:
https://support.microsoft.com/en-us/kb/2990029
https://support.microsoft.com/en-us/kb/2990029 Stop error 0x113 if you use Intel and AMD graphics adapters on a Windows 8.1-based computer https://support.microsoft.com/en-us/kb/2990029 support.microsoft.com
my intel graphic card appear as intel graphic hd family not as 4400
and my lap start getting hot
help needed please
0 kudos
5 Respuestas
Jose_H_Intel1
Empleados
2.412 Vistas
You may try the latest Intel generic drivers; however, it is very likely that the drivers your computer uses were custom made by the system manufacturer. We suggest escalating the issue with DELL*.
https://downloadcenter.intel.com/search?keyword=4th+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4400 https://downloadcenter.intel.com/search?keyword=4th+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4400
mabda2
Principiante
2.412 Vistas
my problem (VIDEO_DXGKRNL_FATAL_ERROR) appear when i update the intel driver to the latest version
then i use the fix from microsoft
but my intel graphic card appear as intel graphic hd family not as 4400
and my laptop start getting heat
i ask microsoft and this is the reply
http://answers.microsoft.com/en-us/profile/096ab490-f08f-4c1b-857a-6ee14955f0dc Navneet Anand
Microsoft http://answers.microsoft.com/en-us/page/faq# faqWhosWho1 Support Engineer
Thank you for posting your query on Microsoft Community.
I understand how you feel about the situation. We apologize for the trouble. The error which you have mentioned in the thread title usually occurs because AMD driver does not support Runtime Power Management, but the Intel driver does support it. I appreciate that you have used the fixit to fix the error.
The Article which you followed discusses third party products which are manufactured by companies that are independent of Microsoft. I suggest you to get in touch with Intel and discuss the behavior with them. You may follow the below mentioned link to reach out to them:
http://www.intel.com/p/en_US/support/ http://www.intel.com/p/en_US/support/
If the issue persists and you still wish to undo the fix which you have applied, then you may try doing System Restore to an earlier date and time.
System Restore helps you restore your computer's system files to an earlier point in time. It's a way to undo system changes to your computer without affecting your personal files, such as e‑mail, documents, or photos.
Refer to the section "Restore your PC to an earlier point in time" mentioned in the following Microsoft Article:
http://windows.microsoft.com/en-US/windows-8/restore-refresh-reset-pc http://windows.microsoft.com/en-US/windows-8/restore-refresh-reset-pc
Disclaimer :Though it is said that System Restore does not affect your personal information such as email, documents, photos, videos, etc., but there is highly possible that some of your personal files are deleted while system restoring.
During System Restore, there may be errors and such errors may cause damage to the files that are present in the system. And, computer shutdown during restoring process may also lead to file loss. Sometimes when System Restore is failed, it may lead to loss of important files as well.
Hope it helps. Please reply with the updated status and for further assistance.
We'll be glad to help. Navneet
MICROSOFT
Jose_H_Intel1
Empleados
2.412 Vistas
What is the brand and model of your system?
mabda2
Principiante
2.412 Vistas
dell inspiron 5537
intel core i7 4500u
windows 8.1 pro
version 6.3 build 9600
Jose_H_Intel1
Empleados
2.412 Vistas
I suggest getting the drivers from here: http://www.dell.com/support/home/us/en/19/product-support/product/inspiron-15r-5537/drivers Product Support | Dell US
Or contacting DELL* for assistance. http://www.dell.com/support/home/us/en/19?c=us&l=en&s=dhs Support | Dell US
Intel supplies generic versions of its graphics drivers for general purposes. But, the computer manufacturer can change the features, incorporate customizations, or make other changes to the graphics driver software or software packaging. To avoid any potential installation incompatibilities, Intel recommends that you first check with your computer manufacturer and use the driver software they provide.
Responder
